Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
    Default Not Happy with my Mojo surf wave, need advice
    I have a 216 Moomba Mojo Surf Edition (upgraded ballast, autoflow, etc...)
    I surfed it all summer last year and had lots of problems getting enough push from the wave to surf without a rope. The only time I am able to continually surf without a rope is about 6-inches from the swim platform, which I know is wrong.
    Tried multiple boards, same results.
    I can surf my friends Nautique 230 all day
    What is the optimal setup for those of you that think you have your Mojo dialed in?
    2016 Mojo (HERE!!!!!)
    2007 Supra Launch 22 SSV Limited
    1990 MasterCraft Tri Star
    1997 Crownline 180BR
    May 2014
    Palm Desert, CA
    Quote Originally Posted by Ramzak View Post
    What's your ballast setup, flow settings, speed, wake plate, elevation, water depth, board, your actual weight/height?
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Well. I have been changing all those parameters all of the 2016 boating season, not sure what the last setting was
    But ballast is about 100% full, didn't notice much difference when messing with level of ballast (50%-100%) all 3 ballasts.
    Flow settings from 65%-100%
    I'm on the gulf coast, so elevation is pretty damn close to sea level
    Water depth ranges from 15' on a local river to 100'+ on some lakes. We go all over the place.
    Tried about 5 different boards mostly rode the CWB Tsunami
    5'8"/200lbs
    If you think you can tell anything from that, please do
    But I'm mostly interested in what others are doing to maximize wave/push characteristics.
    May 2014
    Palm Desert, CA
    5'8"/200lbs
    What's your ballast setup? Stock 650s in the rear? Or do you have more?
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    I don't recall the weight
    But whatever comes stock when you order the Surf Package.
    Aug 2011
    Commerce Lake, MI
    There's your problem. The stock bags are 650 which are useless on the Mojo for surfing. It has a massive hull that needs a lot of volume that needs to be sunk to displace enough water to create a wave with enough push. Same issue we had with my buddies XLV which the Mojo replaced. We had to upgrade to 1100's on that, plus we run extra bags on the seats when we have a smaller crew (3). Weight is you friend for surfing. The 650's are enough for wakeboard but not big enough for a good wave on the Mojo. You need to upgrade both rears to 1100's and are you filling the bow bag to max as well? What speed are you running at? Typically you should be between 10.5-11mph. Double check that with a GPS.
    2017 Moomba Craz
    May 2014
    Palm Desert, CA
    Yes that is not enough. You need 1100s in the rear, some people even put 375-450 under the bench seats. Mojo is a big girl, she needs a lot of weight to sink her down. There's no replacement for displacement.
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Jan 2010
    North Texas
    Of topic, but you had posted up stereo questions back when you got the new ride and never hit us with any pics. I know you had a big equipment list, I was anxious to see how it all turned out.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Dec 2012
    Ennis, TX
    Quote Originally Posted by BrettLee3232 View Post
    This! Mojo needs lots of weight and the stock set up does not cut it. 1100 in the rears are a must. I would even suggest the Enzo sacs for the rears. The Mojo will put out a fantastic surf wave once you get it dialed. Should put you buddies 230 to shame..
    Shane
    2016 Supra SE
    EXILED
    6 XM9 Tower
    6 Wetsounds XS650 Cabin
    1 EXILE BIG 12 DVC 2000 watt in a ported box
    1 XM 15.4
    XI 1500.1
    2 MX 30.2
    Wetsounds 420 EQ
    EXILE Blue tooth EXBT4
    Blue LEDs
    Nov 2014
    Go with the 1450 enzo's and never look back. I put the 1100's in my craz have some regrets about not going bigger.
    2016 Craz.
    Enzo bags.
