Thread: Battery Recomendations
02-14-2017, 11:26 AM #1
Did a quick search and couldn't find anything specific to this topic so I'm starting one. My batteries needs replaced, current ones are the standard Interstate which I can get from Costco for a decent price. Just curious, if I have to spend $200 on batteries are there other options I should consider?
My boat is a 2013, so I should've gotten more life out of them.2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
02-14-2017, 12:22 PM #2Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
All batteries are basically made by 2 or 3 manufacturers and then the terminals, packaging and label are put on for each brand. The point is that a name brand and generic are nearly identical products. I've always used AGM batteries ("sealed", "premium", Optima style) and had good luck. Standard lead-acid seems to last 3-5 years, AGM seems to last 5-7+ years. The AGMs are more expensive but I think a better long term value as I get about 2x the life from them. The last one I bought was the Advanced Auto store brand, I had a coupon and they give a rewards club rebate.
"Marine" batteries are built to withstand more deep discharges, than regular automotive ones. I use standard automotive for the starting battery as we don't use it to pump tunes all day only on battery until it is drained. If you do, consider a marine battery otherwise save your money.2007 Mobius LSV
1989 Sanger Skier DX - sold
02-14-2017, 12:35 PM #3
A good quality group-24 wet cell lead acid will typically serve well for most cranking bank applications. For the 2nd battery or bank, it depends on how its setup and how its used. For some, a dual purpose marine battery is all that needed on both banks while others need a dedicated house bank will a high amount of Ah. This could come from one or two wet cell deep cycle, AGM or even a pair of 6V golf cart batteries.
02-14-2017, 02:31 PM #4
do you keep a battery tender on them at all? I usually keep mine plugged in if the boat is sitting for more than a couple of weeks. I have a built in charger that seems to work great.
Scott
2021 Craz
1997 Sea Ray 190
02-14-2017, 02:37 PM #52017 Centurion Ri237
