Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
    Sep 2005
    Claytor Lake, VA
    Your ballast system is missing 2 valves. They are sprinkler valves you can pick up at any big box home improvement store. I would focus on fluids as stated earlier.
    2005 Mobius LSV
    325 EFI
    Apr 2014
    Owensboro, KY
    As stated by VA LSV you are missing two of the Orbit Sprinkler valves that go on the ballast manifold. They are just like the one on the end and will connect via those quick connect hoses.
    The pump you are mentioning up front is most likely the drain pump for the front bag. There should be two of those in the rear as well.
    Feb 2017
    Birmingham, Al
    Thanks all for the comments. I assure you all my fist focus is on getting the tranny and v-drive drained and changed. That makes sense on the connectors for the additional two pump in lines. Here is an additional question on that though. If there is one pump on their and 3 valves always open, why do I have 3 switches? One for the front and two for the two rear bags. As I see it, if the pump comes one all 3 bags would fill. What am I missing here?
    CraigXLV
    2008 Moomba XLV Gravity Games Edition
    Jan 2010
    North Texas
    The switches control the 3 valves, 2 of which you are missing, which are for the front(1) and rear (2).
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Sep 2005
    Claytor Lake, VA
    The fill pump runs when any of the 3 valves are switched on.
    2005 Mobius LSV
    325 EFI
    Commerce Lake, MI
    Craig, where are you located? Maybe a local meme we can come and show you some things and look the boat over. Way easier than trying to explain and diagnose things on a forum.
    2017 Moomba Craz
    Gravity III has a front bag a right and a left. When you turn on any fill switch the single fill pump (Rule 2000, 1200 GPH) turns on and the sprinkler valve for that switch opens. Each bag has its own empty pump (Rule 700 I think unless already replaced).
    Feb 2017
    Birmingham, Al
    Hey Stazi, I am in Alabama. Sorry I have not completed my profile. Guess there is a need to do that. I think I get it now. I am just shocked at how the system is so half way configured on tow of the pumps, but one is complete. Not that the one zone would even work because if I tried to pump water in the competed zone now water would go everywhere with the other two zones completely open. Now I need to see if I can track down the wiring that would connect to the other two sprinkler valves that I will need to install. Thanks again for everyone's help.
    CraigXLV
    Commerce Lake, MI
    Maybe the previous owner canabalized the system? Should have had at least one bag hooked up to it somewhere. Honestly, you can add the sprinkler valves for now, but after about 2-3 outings of trying to fill all those bags of one aerator pump, you'll be on wakemakers ordering the reversible pump upgrade kit. Trust me it's well worth the money.
    2017 Moomba Craz
    Find the wire going to the existing sprinkler valve. Trace it back to the loom. Look for two other wires coming from the same loom that have the same plugs on them. Hopefully the previous owner just unplugged the valves and did not cut wires. Should be gray or black plugs. Can't remember wire colors. One might be purple and one green? Anyone recall?
Tags for this Thread
