Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
    Apr 2013
    Knoxville TN
    I have a 2007 supra that I upgraded.
    This is what the sprinkler valve system looked like when I took it out and sold it.
    Apr 2013
    Knoxville TN
    Also had the same pump. So long to that slow fill time. . . .
    Apr 2013
    Knoxville TN
    The little black switch opens/closes the valve. Make sure those are not broken.
    They cost around $25 each for the whole valve.
  4. #24
    Apr 2013
    Knoxville TN
    Also, to drain the bags, you need 3 other pumps to get the water out. These were from a Supra, but I think Moomba used the same.
  5. #25
    Feb 2017
    Birmingham, Al
    I have identified all 3 pump out pumps. Your picks of the valves is exactly what mine should look like. I still cannot figure out why mine only has the one valve with the other two ports completely open. I will soon look at getting the valves for mine. I will likely just try and get mine operational this year. I still have to buy bags as well.
    CraigXLV
    2008 Moomba XLV Gravity Games Edition
  6. #26
    Feb 2017
    Birmingham, Al
    MJKSupra, where can I find those valves with the plugs already on them?
    CraigXLV
  7. #27
    Commerce Lake, MI
    You won't find them with the plugs on them. Those are put on by SC. The valves you can buy from Lowes or Home Depot.
    2017 Moomba Craz
  8. #28
    Apr 2014
    Owensboro, KY
    Craig,
    Not sure what your time frame is but I am thinking about going to the wakemakers kit. If so I will have my GIII stuff available. Will know in about 30 days.
  9. #29
    Feb 2017
    Birmingham, Al
    Let me know JHutch. This will be the last item on my list of may things to do.
    CraigXLV
  10. #30
    Apr 2013
    Knoxville TN
    If you can buy from JHUtch, buy all the parts. Then you will spares. That is what someone did when they purchased mine. Any of those parts (used) are hard to find.
    Otherwise, you can get the valve from Lowes/HomeDepot.
    Or buy both parts from a dealer - valve and solenoid. Pay more.
    2018 Supra SL400
Tags for this Thread
