Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 180
  1. #161
    Commerce Lake, MI
    Then I zip tied it to the underside of the steering rack. Knobs aren't visible, but I can reach under there and turn the towers up and down easily, and adjust the sub for subtlety or crank it up for a testicular massage.
    2017 Moomba Craz
  2. #162
    That looks great! Speakers fill the tower
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  3. #163
    Commerce Lake, MI
    Here's the zone controller mini rack I made.
    2017 Moomba Craz
  4. #164
    Nov 2014
    Columbus, Ohio
    Haha, that's exactly what I did.
    Boatless for now
  5. #165
    The Kicker ZXM-RLC knobs can also be removed from the housing and panel mounted.
  6. #166
    May 2014
    Palm Desert, CA
    Or ACC switch mounted
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
  7. #167
    Commerce Lake, MI
    Yeah like what you did Brett.
    2017 Moomba Craz
  8. #168
    Quote Originally Posted by Rakkasan View Post
    Let's build something
    What clamp did you have to order to use the stock mounting location?
  9. #169
    Nov 2013
    West of ATL
    https://wetsounds.com/cgi-bin/shoppe...=WSACNAT-FC5-U
    This is what I have with the Rev10 X-Mount. My biggest concern was not knowing if the tower was pre drilled for the adapter as I couldn't find any pictures online. But rest assured the tower IS pre drilled and fits perfect.
    2008 LSV on the way out
    '17 CRAZ!!! on the way in
  10. #170
    Apr 2017
    Hayden Id
    used some homemade mounts to hide the wires,
    2017 Craz surf auto wake
    1140 # rears wet sounds
