Results 1 to 5 of 5
    May 2014
    Palm Desert, CA
    Default Bullet Lines Ballast Bag/Pump?
    Anyone use these? On sale for cheap!!!!
    Bullet Lines 550 lb Ballast Bag w/ Cover $59.99
    http://www.bulletlines.com/550-ballast-bag-p/223.htm
    Bullet Lines 350 lb Ballast Bag w/ Cover $59.99
    http://www.bulletlines.com/350-ballast-bag-p/224.htm
    Bullet Lines Fat Sac Pump $59.99
    http://www.bulletlines.com/universal...c-pump-p/5.htm
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
    Waterbed fittings on ballast sacs are SOOOOO 2000's. The reason they are so cheap is because these are a retired sac design from 10 years ago. After a few times out, you will hate those fittings. Go with quality ballast sacs and pumps from a reputable outfit like Fly High.
    May 2014
    Palm Desert, CA
    Thanks mike. That's why I asked
    2015 Mondo
    2079 Prop
    Auto Flow 2.0
    Mar 2014
    Park City, Utah
    From the perspective of adding cheap ballast, this is actually a good cheap option as long as you get their bags and their pump with their fittings. You wouldn't be able to use them as a universal bag as these fittings suck in comparison to fly high or eight.3, but if you want a bag or two extra to try to see if the added weight improves the wave?
    2017 Centurion Ri237
    2013 Supra SA450 - Sold
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    The Fly High W735 fitting will allow the use of the Fly High W709 Pump Kit for filling/draining of those old waterbed fittings. I think you could put a W732 on the pump inlet and W738 on that pump in the link and fill a fly high sac. Just an FYI.
