Results 1 to 7 of 7
10-24-2016, 12:04 PM #1Senior Member
- Apr 2014
- Owensboro, KY
- 204
Water Drain Plugs in Walters V drive
So it was my first time trying to do my own winterization and all was going well until I hit a snag. The drain plugs in the V drive are stuck? I wrenched on them until I was afraid they would break, any ideas how to get them loose? Or will I be alright just removing both hose and blowing air through the V Drive and then putting some antifreeze in it?
10-24-2016, 02:31 PM #2
I had the same issue and I blow air through and then antifreeze and blow that through and then add some more antifreeze. No issues and I am in Canada.
10-24-2016, 08:48 PM #3
10-25-2016, 10:36 PM #4
+1 ^^^^^^^
09 21v LAUNCH
99 Outback LS. Sold
Doug
10-28-2016, 11:39 AM #5Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Replaced my original steel plugs with hex head brass plugs. Was a struggle to get the steel ones out. Ended up using vise grips. Brass ones don't corrode in place plus you can use a box end wrench or socket on them. Same plugs fit my engine block drains.
2005 Mobius LSV
325 EFI
10-28-2016, 12:58 PM #6
Same here. They come out easy.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
10-28-2016, 09:03 PM #7
On the Walter, the cooler is typically higher than the raw water inlet scoop. So, once the boat is pulled out of the water, most of the water in the cooler runs out the inlet side. On the outlet side, water tends to get trapped in the hose going to the engine due to a dip. Pull the hose and let that water run out. In short, Ive never needed to pull the actual plugs on a Walter.
