    Jun 2016
    Vonore TN
    Default wakek plate not moving much
    I have a 2007 Moomba XLV and my wake plate only moves very slightly.. like not more than 1 inch.. the indicator on the dash also shows its not moving much. can I get some advise on how to trouble shoot?
    I think your boat still has the hydraulic actuator. Start by checking the fluid level. There should be a reservoir in the engine compartment. It may be mounted to the aluminum bracing that is up against the rear bench seat.
    Sep 2005
    Claytor Lake, VA
    Agree, check fluid level first. Uses standard ATF fluid. If it is low you will need to operate it several times after topping off the reservoir to work the air out. Check for leaks at the actuators on the wake plate.
    2005 Mobius LSV
    325 EFI
    Jun 2016
    Vonore TN
    perfect going for an evening ride this evening and will check that out.
