    Sep 2016
    Default Solenoid Help!!!
    My ballast were taking on water (with the switch in the correct position) so I went and bought the replacement Orbit vales. However, the old solenoids have the special clip style adapter. The wires are not marked. I was going to cut and splice, but how do I know which one is which?? Help is appreciated!!!!
    Thanks,
    Rob
    Aug 2012
    Morganton, NC
    It doesn't matter which goes to which.
    Sent from my Nexus 6 using Tapatalk
    2008 OBV
    325 EFI with closed cooling
    Gravity III with 750's in the rear, 400 stock floor, 750 IBS
    Servo valve ballast upgrade
    Wetsounds Rev10
    JL Amps, WS420BT
    2000 Outback LS <-- Sold!!!
    310 Carb Direct Drive
    800# Rear Locker
    750# IBS (should have kept this for the OBV)
    Dual Batteries with 2 Bank Charger System
    Kenwood Head with Remotes
    Too many hours restoring exterior from prior negligence to count!
    Ditto san!
    Sep 2016
    Thanks guys!!!
Tags for this Thread
