Results 1 to 8 of 8
Thread: 4 Ballast pumps and manifold
09-18-2016, 02:18 PM #1
1 Rule ballast pump
3 Rule 700 ballast pumps
1 sprinkler valve manifold
jjolson is working on a ballast upgrade and now has some spare parts. All in good working condition. Make an offer.
09-18-2016, 04:57 PM #2
Are they able to be split up? Interested in the large single Rule supply pump
Sent from my Nexus 6 using Tapatalk2008 OBV
325 EFI with closed cooling
Gravity III with 750's in the rear, 400 stock floor, 750 IBS
Servo valve ballast upgrade
Wetsounds Rev10
JL Amps, WS420BT
2000 Outback LS <-- Sold!!!
310 Carb Direct Drive
800# Rear Locker
Kenwood Head with Remotes
09-18-2016, 05:30 PM #3
If I can find a good home for the rest of the stuff, sure.
The 700s work well for draining a bow sac on each leg.
09-19-2016, 08:23 AM #4
Forgive my newb question, I currently have gravity I system with only center tank on a switch. Would I be able to upgrade to gravity III like system with these parts?
Thanks for the help.2007 Mobius LSV
09-19-2016, 09:55 AM #5
09-21-2016, 12:00 PM #6
09-21-2016, 09:05 PM #7
09-22-2016, 10:50 AM #8
Damn and I carelessly chucked mine in the trash. Glad you found a home for it.
2007 XLV Gravity Games
1,100 in each rear locker
1,180 in front
Fresh Air Exhaust
SuckG8
Bunch of other crap
