Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: IBS Questions
  1. #31
    Oct 2013
    Ft. Collins, CO
    IIRC, the bag in the center locker has two ports and both are used: the lower for fill, the upper for overflow/vent. They used Fly High/Flow-Rite fittings like these from wakemakers
    1989 Sanger Skier DX - sold
  2. #32
    May 2017
    You are correct it only has two ports. I want to add a port on top of the center locker bag to feed the IBS.
    Looking for input on the best part to use, I've seen info on how some have added ports to a bag.
    New to boating and surfing
  3. #33
    Oct 2013
    Ft. Collins, CO
    Seems unnecessary... I would tee off of the overflow/vent since it is already right behind the helm.
  4. #34
    May 2017
    So T off the fill line to the IBS and back from the IBS and T into the drain line?
  5. #35
    Apr 2012
    Wake Forest, NC
    I think you would want to add a fitting to the front of the center floor sac so it doesn't fill with air. My 2008 had a plug at the front of the bag. I added a fitting and and tee'd from that to both sides of the ibs legs by drilling a hole in the floor on both sides. Used a couple 90" couplers for the tight bends.
    2018 Murder Max
  6. #36
    May 2017
    What dit you use to drill thru the floor?
  7. #37
    Apr 2012
    Wake Forest, NC
    Quote Originally Posted by MGX View Post
    A hole saw like this that goes on the drill:
    2018 Murder Max
  8. #38
    May 2017
    Thanks, did you drill thru the carpet with it? I don't have a vent on the center bag, might add one...
  9. #39
    Apr 2012
    Wake Forest, NC
    Yep, right through the carpet. Made a clean cut in the carpet.
    2018 Murder Max
  10. #40
    Oct 2013
    Ft. Collins, CO
    Does water overflow out the side in front of the driver when it's full? That would be the vent.
