    Jul 2013
    Windsor ON
    Default First time Winterization attempt
    I am looking to do the winterization myself this year and was looking for a link to another thread or a step by step on how to do this.
    I typically change my oil every spring as well as the impeller.
    The boat is in heated storage at a friends but I winterize it regardless in case something happens with the heat.
    I have a 98' outback.
    Any help or tips would be greatly appreciated.
    -Chris
    Jan 2011
    Western PA
    Pretty much follow
    https://forum.moomba.com/showthread....w-and-improved
    I run it on a garden hose until the thermostat opens up totally. (Max temp).
    I drain the block and manifold hose, suck out the oil, change the filter, but then run a 5 gal bucket of antifreeze thru and shut it down.
    2017 Moomba Craz
    400 Indmar Rapter 6.2L
    "X-ceeding Limits"
    2004 Supra 22 Launch SSV-crushed by a massive oak tree. RIP 4/1/2023
    325 Indmar Assault 320 HP
    "One more hour"
    Oct 2008
    Central, Arkansas
    What he said.. ^
    I also change the fluids during the winterizing. I would rather have new fluids sitting all winter than used. I also pull the impeller and put in a new one in the spring.
    2014 Mojo Surf
    2013 Mojo Sold
    2010 LSV Sold
    2002 OB LSV Sold
    Apr 2013
    Knoxville TN
    I have a 2007 Supra and learned from that same thread. Awesome thread - even tells you the wrench sizes.
    I run my boat after fluid changes during year-end.
    I changed the impeller last year. It gets removed each year (probably do not need to do that), but it will last multiple years for me.
    If I take it out and notice something on the blades, it gets changed with the gasket during the following year.
    I have different ballast pumps, so I have loosen all the hoses to get the water out. I use air in the lines to push the water out.
    My ballast bags are removed and sit in the garage all winter. So do the impellers for the pumps. In bags with vaseline.
    I you have a heater in the boat, that will need to be addressed.
    Different people have different opinions about draining water from the block vs. filling with antifreeze.
    I also make sure to get ALL water out of bottom of the boat. No need for moisture/mold.
    Last year I also put a bucket (64oz) of DampRid in the boat. I was amazed how much moisture that picked up when stored a semi-heated garage.
    Mar 2003
    Springfield Missouri
    What engine do you have? I'd recommend removing any ethanol gas by disconnecting the gas line at the carburetor, jumping the fuel pump and drain the gas into cans. Put a couple gallons of ethanol free with Stabil into the tank and pump it through, connect the gas line, run the engine and fog the carburetor. Shut off the engine, pull the heater hose and blow out, pull the J hose on the water pump, pull the raw water hoses off the impeller pump and blow out the water intake, blow out the shower lines with the pump running (use low air pressure), pull the riser plugs and open the block drains. I pull the coil wire and turn the engine over for a second to seat the impeller and blow out the water in the exhaust. Put all the hoses back on. Connect a trickle charger to the battery.
    1998 Mobius
    310 HP PCM
    SOLD
