Results 11 to 15 of 15
Thread: Garage Heater Help
09-19-2016, 03:43 PM #11
Garage Heater Help
2013 LSV Red/White
1100lb upgrades in each rear locker!
Stock 500 Bow ballast
650IBS
Manual Flow equipped
Boards
Hyperlite Hi-Fi "The Illest"
CWB AMG Carbon
Phase 5 Razz
Byerly Volt
4.6 Ronix Koal Fish
Phase Five Scamp (kiddos)
11-08-2018, 07:39 AM #12
My garage is 24x26 attached garage with a 10 foot ceiling. I live in the Chicago area so the cars tend to be down in winter and that is prime time to repair/upgrade then.
The garage is completely insulated and seldom gets below freezing. For the past few years I have been using a portable propane radiant heater. It will keep the garage at 45-50 but never quite felt comfortable.
Last years’ Polar Vortex and my aging body motivated me to do something more.
Above the garage is the master bedroom so doing a Natural Gas furnace was going to cause quite a bit of work for the chimney. My local laws state the top of the chimney must be above the highest peak on the house. So this ruled out a natural gas furnace.
I broke down and decided to buy myself a Christmas present. I ordered an electric ceiling mount ProFusion EH-4604 from Northern Tool & Equipment like this https://10carbest.com/best-garage-heaters It is rated at 17,000 BTU which is much better than the 7,000 BTU propane heater I had been using.
I did have to run a 220V 30A circuit to the garage which wasn’t difficult. (I did get help to make sure it was done right). I used an AC disconnect switch so I can kill the power to the furnace when not in use. The installation was very simple and I am happy to say the garage was over 60 last night when the outside temperature was in the teens. I had the heater on the 5000 watt setting for about 30 minutes and then turned it back to 3000 watts.
I have been using it for about 1 month on the weekends. The garage will be at 32-35 when I turn the heater on and usually <20 outside. It takes about 1.5 hours on the 5000 watt setting then I put it on the 4000 watt setting for another hour. Within 2.5 hours the garage is at or above 60. I set the furnace to the 3000 watt setting and it will run about 15 minutes every hour.
I am very happy with the results, the fan has sufficient volume to move the air around and keep everything toasty!
11-08-2018, 02:07 PM #13
Garage heater? Never heard of such a thing.
11-08-2018, 09:00 PM #14Member
- Oct 2018
- Spokane, WA
- 42
I put in a mr heater 50k btu for my 2 1/2 car attaches garage, it works great and was only $400 on amazon. They make a bigger one that’s 80k btu I believe.
I had an hvac put in Incase it burns the house down, I don’t think insurance would cover the house if you DIY.
11-15-2018, 07:05 AM #15Junior Member
- Nov 2018
- USA
- 1
I have that model Dayton in my 20x24x8 detached garage. I have it set just high enough to keep stuff from freezing, and then turn it up while I'm working. Works fine, and hasn't been terribly expensive.
2017 Moomba Helix
