Results 1 to 7 of 7
    Aug 2015
    Birmingham, AL
    Default Bent prop shaft mount
    Never fails... Just got my boat out of the shop and the day before labor day I take it out and hit a log floating below the water. Now there is vibration when I go above about 2k RPM.
    It looks like the mount that holds the shaft right before the prop is bent over to the left a little bit. Probably about an inch or less. Could I try to bend this back? Or does it have to be perfectly aligned professionally? How much should I expect to pay?
    Any help it appreciated, it is always something
    You'll never get it right. Best to replace the strut with one like from skidim:
    http://www.skidim.com/STRUT-MOOMBA_S...ctinfo/101029/
    You'll need to do an alignment after the replacement. You can do this yourself. There are good instructions found on here:
    https://forum.moomba.com/showthread....ight=alignment
    May 2013
    Spokane, WA
    You didn't hurt prop? I hit something this weekend back out of dock of all things. Couldn't go past idle or boat wanted to rattle apart. Had to idle 3 miles back down to launch to pull boat out.
    2013 LSV Red/White
    1100lb upgrades in each rear locker!
    Stock 500 Bow ballast
    650IBS
    Manual Flow equipped
    Boards
    Hyperlite Hi-Fi "The Illest"
    CWB AMG Carbon
    Phase 5 Razz
    Byerly Volt
    4.6 Ronix Koal Fish
    Phase Five Scamp (kiddos)
    Aug 2015
    Birmingham, AL
    Thanks so much! I actually forgot about this post, googled bent prop shaft, and found this post that was mine in the first place! Haha. I have ordered the strut you mentioned and will try to roll on based on your recommendations. HUGE help!
    Aug 2015
    Birmingham, AL
    Also, the log chipped off a piece of the gel coat. Is this a DIY fix? I am not worried about perfection, just want it to be fixed. Otherwise I will take it to a fiberglass shop in town and see what they think.
    A shop can fix it pretty cheap and mix colors a lot closer than you can. Check over the whole boat and have them address everything while it's in there. But, have them do it.
    Aug 2015
    Birmingham, AL
    Will do. Thanks!
