Results 1 to 3 of 3
Thread: Prop shaft thread pitch/size
09-04-2016, 03:45 PM #1Member
- Jul 2014
- Eastern Ontario
- 72
I am wondering if anyone knows what the size and pitch of the thread is on my boat. Have to remove and repair my prop cause I hit a gravelly sandbar last night (low water conditions) its dinged up a fair bit.
There is no source around here that I can get a (harmonic or C) puller quick but I can get the guys in the machine shop at work to make a harmonic puller quick if they have a tap. What is the material of the puller?
There is also a variety of bearing/gear pullers with two claws on them at work. I could try them as well I guess.
Thanks folks
Regards
Blueliner2007 Moomba Mobius XLV with G3 Ballast, 325HP Indmar, Carbureted
Extreme Noob
09-05-2016, 12:25 PM #2
You don't need the nut size or thread. Just have them make you one like this out of a C clamp:
https://www.wakemakers.com/acme-c-cl...FYU0aQodlH0HKg
This chart might help with the nut for your shaft:
http://www.propshopinc.com/Nut-Kit-S...llers-p30.htmlMy Mom said I'm not allowed to get wet!
09-06-2016, 08:09 PM #3Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Thread size is 3/4 - 10.
2005 Mobius LSV
325 EFI
