Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Apr 2016
    i'm certainly not a hydraulic engineer or boat builder, but i think "the bigger the boat, the better the surf wake" is a myth. I actually think the shorter the boat, the less additional weight it takes to make a quality wave. I have nothing to back this up with other than anecdotal. the more surface area that contacts the water the more weight it takes to sink the boat deeper in the water. but the deeper the boat travels thru the water, the more the water displaces around the hull and converges behind the boat for a better wave w/less weight in the boat. so in a factory to factory ballast comparison, i think the shorter boat has the advantage. but you give up other features, like interior room.
    2016 Craz
  2. #12
    Henderson, NV
    I could be mistaken and wolfman has been to more than probably most on this forums, but doubt many of the contests are being pulled by 20ft boats. seems that the 23ft boat seems to be the boat of choice for most contests.
    now do get that the boat manuf. want to sell the larger boats so hence the reason to have them pull the contest, but you also want the best wave out there when it's being broadcast or posted across the internet and betting in most cases, it's that 22-23 ft boat in the lineup.
  3. #13
    Nov 2014
    A larger boat displaces a larger volume of water and creates a more powerful wave. Ballast ed or not, a bigger boat will displace more water. Think about rollers from passing boats. Bet you've had far more close calls with rollers from large boats than from small ones.
    2016 Craz.
    Enzo bags.
  4. #14
    I'm pretty sure that water displacement is a function of weight (rather than length)... at rest.
    Once you get moving, the hull length, width and shape can offset this... at the same weight.
    Length? Girth? or Weight???
    2007 LSV
    2315 Acme prop
    Gravity III + 3 Johnsons
    1100s in the rear, IBS upfront
    Stock bags under the seats
    HDPE Surf Platform
  5. #15
    Henderson, NV
    Quote Originally Posted by Leebo View Post
    insert bad joke here.....
  6. #16
    Jul 2015
    Northeast WI
    I got a good laugh out of that!
    2016 Craz
  7. #17
    Mar 2016
    Birmingham Al
    Default Craz or Helix for better wave?
    Craz,
    Mic drop
  8. #18
    Mar 2016
    Birmingham Al
    O_o
    Hahahahahaha
  9. #19
    Apr 2016
    Traverse City, MI
    Stock Helix with my son who can't get enough of it.
    2016 Helix
  10. #20
    May 2014
    Palm Desert, CA
    Nice helix wave!
    2015 Mondo
    Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
    2079 Prop
    Auto Flow 2.0
    Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
