Results 1 to 8 of 8
08-14-2016, 08:39 PM #1Member
- Jun 2011
- Cincinnati, OH
- 36
Replacing Sony Cdx m60ui head unit
My head unit finally bit the dust this weekend after intermittent issues all summer long (was down to only the USB function of the head unit working). Looking online shows me that this unit has been discontinued by Sony. Is there a compatible head unit that works with my wired remotes or do i need to replace both of those as well. If going with a full replacement what type of options do you guys recommend? Thanks.
2014 MOJO 2.5
08-14-2016, 09:36 PM #2
Not that I have found. , you will need one new remote the transom Sony should still work
08-14-2016, 09:47 PM #3
What remotes do you have? last i checked, Sony was down to only one active model that supported the LCD remotes and two that only support the non-LCD.
08-14-2016, 10:44 PM #4Member
- Jun 2011
- Cincinnati, OH
- 36
i have one LCD remote (RMX60M/L) at the driver seat and the non LCD (RM-X11M) as the transom
2014 MOJO 2.5
08-14-2016, 11:38 PM #5
The Rmx60m/l is only designed to work with these older receivers.
CDXM60UI , CDXH910UI , and DSXMS60.
The 11 should work with most new ones .A Day at the Lake...Priceless
08-14-2016, 11:54 PM #6Member
- Jun 2011
- Cincinnati, OH
- 36
If i buy one of the newer sony head units, is it as simple as buying the new LCD readout remote with it and plugging it in where the existing one is now? Hoping that the non LCD transom remote is still compatible?
2014 MOJO 2.5
08-15-2016, 08:01 AM #7
Should be check accessories for compatability
08-15-2016, 08:29 AM #8
