Results 1 to 2 of 2
Thread: prop shaft replacement
08-13-2016, 02:43 PM #1Senior Member
- Oct 2013
- 135
so I'm removing my prop shaft after hitting a log the other night I'm just about to remove the flange that bolts to the v drive my question is at such a time i get a new drive shaft (if it is bent) does it just slide back in and the dripless shaft seal just automatically seal. its on a 2013 obv
2013 outbackv
08-15-2016, 10:14 AM #2
Your new shaft will come with instructions that say to tape over the threads so you don't damage the seal and put a little marine grease on the tape before you slide it through. Good luck!
