Results 1 to 8 of 8
    Nov 2014
    Default Growling/Vibration
    2014 Möbius LSV with 330 assault. Running Acme 1433 prop. Just recently my family and I have begun to wake surf. When the stock rear and center bags are full and getting going at 10 mph I can feel a vibration and hear a growling noise coming from trans/motor area. The noise only comes when boat is heavily loaded. All wakeboarding actions nothing can be heard. I have used boat for a few days and noise has not gotten worse or better. I am going to switch to my stock 537 prop and see if noise is there still tomorrow. Any ideas before I take in to shop?
    May 2013
    Spokane, WA
    Quote Originally Posted by tjbere View Post
    Mines been doing it for last couple years since I added more weight and I run acme 1617 prop. It's not cavitating, or slipping that I have noticed - but it is annoying. Like you said it only does it fully sacked out or heavily weighted.
    2013 LSV Red/White
    1100lb upgrades in each rear locker!
    Stock 500 Bow ballast
    650IBS
    Manual Flow equipped
    Boards
    Hyperlite Hi-Fi "The Illest"
    CWB AMG Carbon
    Phase 5 Razz
    Byerly Volt
    4.6 Ronix Koal Fish
    Phase Five Scamp (kiddos)
    Mine has been doing this ever since I bought it in 2010. The stock OJ prop was supposedly known for this and swapping to an ACME was the fix, well I swapped to an ACME 1847 like 4 years ago and it still growls/vibrates.
    2017 Moomba Mojo Max Surf Edition, 2 Pair Wetsounds Rev10s powered by an SD2, 6 pair Wetsounds XS650M and Wetsounds XS12 powered by SD6 all controlled by a WS420.
    Definitely check your drive shaft coupler bolts. Should do this at every oil change.
    May 2013
    Spokane, WA
    I did. Everything is solid all the way back.
    2013 LSV Red/White
    650IBS
    Boards
    CWB AMG Carbon
    Phase 5 Razz
    Byerly Volt
    4.6 Ronix Koal Fish
    Nov 2014
    I checked mine over too. Everything tight. Im gonna do a propsaft alignment as when I checked that I could get .007 in at port side at like 2 o'clock and 6 o'clock.
    I don't really know if that small amount out of adjustment would make a difference.
    Nov 2014
    After prop shaft alignment and putting my new 1617 on. all is well. I may have a prop problem sending out to Nettles on Monday. One thing to note I never properly lapped my 1433 when installed. That may have been my issue all along. I will find out next week if prop was out of balanced.
    What do you mean by "Lapped" your 1433?
