Results 1 to 7 of 7
    Jul 2016
    Logandale, Nevada
    Default 2007 Moomba Mobius Wakeboard and Surf Settings
    Just purchased a 2007 Mobius LSV, and curious what the best settings are for wakeboard and surf.
    I have the stock ballasts, so 400lbs on each side of the rear. Willing to get some extras if needed, but please let me know your thoughts on settings. Thanks in advance!
    Apr 2014
    Lake Allatoona; Woodstock, GA
    Just got into the surfing over the last few weeks and you'll need a lot more ballast. I've got 500 in the bow, ski locker full, and 1k bags in each rear plus the suckgate everyone is making. I run the surf side full and opposing about 70% with suckgate on opposite; and we run about 12, no perfect pass. Stock prop. Others may have more optimal setups, this was the best we've had so far.
    Wakeboarding with stock ballast was fine with a shorter rope - brought in 2 loops to have a landing on the downslope of the wake.
    Jeff
    2007 LSV - FAE, G4 setup with Sumo 500 IBS, 1k rear lockers
    Jun 2016
    Vonore TN
    I have the 07 XLV.. as I have told many people build a suck gate.. I just also ordered two 1140 bags for the rear as I have found with about 5 avg males in the boat for weight with the suck gate the wave is great.. that's with the bow bag pretty much full as well Wake Makers has an upgrade to the 1140's for under $500 and there is a code you can get for 10% off if you order. Just my thoughts good luck
    Oct 2013
    Ft. Collins, CO
    Agree with other comments about wanting (needing) more ballast for surfing. Without a suckgate, we run locker and IBS full, slammed full 1100 surf side and some amount non-surf side depending on crew; the trim tab is usually in the range of 1/2-2/3 down; and almost always 10.5mph. We haven't used a suckgate enough to advise but above comments seem right.
    For wakeboarding, you'll make a nice wake with the stock setup all full. I tend to also run the IBS full (depending on crew) and maybe a bit more weight than the stock bags would offer but planing out starts to become an issue with too much weight. The trim tab is usually around 1/2 down but we tweak it depending on all other factors, and sometimes have to trim full down to get on plane and then set to desired position. I like 21mph.
    1989 Sanger Skier DX - sold
    Jul 2016
    Logandale, Nevada
    Default Thanks Guys!
    Quote Originally Posted by gregski View Post
    Thanks guys, this will get me going in the right direction!
    Aug 2011
    Default Re: 2007 Moomba Mobius Wakeboard and Surf Settings
    1100s, center and ibs all full, plus a suck gate..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
    Des Moines, IA
    Quote Originally Posted by parrothd View Post
    Yep. You said best so best is going to be running it slammed. We got a better wave slightly listed with the suck gate so try moving the people in the boat to the surf side or dripping some of the weight on the opposite side 1100.
    You can get a really good wave with only stock rear bags full and a suck gate too.
