Results 1 to 10 of 17
Thread: Those with Docks, Slips
07-26-2016, 04:50 PM #1
For a couple questions for those who use slips, docks.
The ole Mojo been in the water about a week, sometimes when I'm at the dock I notice the bilge running.
Question 1, do y'all notice this? I haven't looked to see if I have water leaking but then again I almost think this is normal.
Question 2 my bilge runs for a long time with a weak stream (insert old man joke) how do you take the bilge pump apart to clean it?Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-26-2016, 05:06 PM #2Senior Member
- Aug 2011
- 2,522
Re: Those with Docks, Slips
It's normal, open the hatch and take a look for incoming water, it'll most likely be the packing nut. It'll be dripping or slight trickle of water, it's supposed to.
If the bilge is constantly running like every 10-20 minutes you need to figure out why. There may not be enough water in the bilge for full power, just enough to kick the pump on and it trickles out.http://www.instgram.com/jlyons30
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
07-26-2016, 05:16 PM #3
I'll watch it but I think it's only every few hours if that.
Today I came down and jumped in the water to cool off, climbed in the boat to avoid sand on the beach and I think me shifting the boat back kicked it on.
I've noticed it running more when on the lake this year but when I look I don't see anything specific.
Although the other day after surfing and then draining ballast, the bilge drained and my belt was squeaking like it got wet and the bilge ran a long time which threw up my red warning flags to pay more attention lolMalo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-26-2016, 05:23 PM #4Senior Member
- Aug 2011
- 2,522
It may have crap in the filter/screen, the pump should have little push in side clips that will allow you to remove the pump, that could be making the noise too..
07-26-2016, 06:48 PM #5Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
I've had the bilge pump drain line get "clogged" with stuff that could get through the pump but not out the line. I disconnected the hose from the pump and then connected a garden hose to "blast" it clean. You could probably also "back-flush" the line by holding the garden hose to the hull fitting (still disconnected from the bilge pump). Those bilge pumps deliver good flow but not much pressure.
1989 Sanger Skier DX - sold
07-27-2016, 10:36 AM #6Senior Member
- Jan 2011
- Western PA
- 100
Prob packing nut as mentioned.
Since I trailer, I only check it when leaving it in the water for a week long vacation.
I don't believe it should drip at all while sitting idle.2017 Moomba Craz
400 Indmar Rapter 6.2L
"X-ceeding Limits"
2004 Supra 22 Launch SSV-crushed by a massive oak tree. RIP 4/1/2023
325 Indmar Assault 320 HP
"One more hour"
07-27-2016, 06:45 PM #7
The bilge just snaps into the base. Very easy to pop out by squeezing the side tabs in. You will see the screen and impellar once out.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
07-27-2016, 10:51 PM #8
I'll be looking into it
[COLOR="#696969"]
07-28-2016, 01:31 PM #9
Never had either of mine turn on from just sitting in the water, may have a leak
07-28-2016, 01:42 PM #10Senior Member
- Aug 2011
- 2,522
Lol.. mine are on every 20 minutes..
