07-26-2016, 12:57 PM #1Junior Member
- Jul 2016
- 3
fuel filter (s) for 2008 outback 325 Assult engine
Having a big problem in this heat with vapor locking after running then letting it sit while swimming. just will not start. want to begin by changing fuel filter but not sure A) where it is located (may be an inline somewhere) and B what the part number is. any ideas
07-26-2016, 02:11 PM #2
If same as a 2007 Outback DD, the fuel filter is accessed via the rear, 2-piece sundeck. Open the sundeck and locate the screws which hold the inside compartment panels in place. Remove the screws and lift out the panels. You will see the fuel filter secured above or behind the fuel tank. Easy remove and replace.
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
07-26-2016, 02:27 PM #3
if it is a v-drive like my 07 LSV then you just need to remove the back seat and the fiberglass cover and it is on the drivers side. Really easy to see and change. Here is a thread that talks about the part #https://forum.moomba.com/showthread....r-a-Mobius-LSV
Scott
2021 Craz
1997 Sea Ray 190
07-27-2016, 05:13 PM #4Junior Member
- Jul 2016
- 3
Thanks guys mine is a 2008 outback DD but I bet it is the same as the 07 I will go through the rear 2 piece and look there Thanks again.
