Results 1 to 10 of 12
    Apr 2013
    Richmond, VA
    Default Getting crushed on the TS360
    The TS360 seems to be a brutal trick to learn.
    I hang onto that rope and either slammed into a whiplash backsplat (too late on the handle pass) or I take it in the face (made the handle pass).
    I am going to get some video so that everyone can have a good laugh at my expense.
    I always think I have it and then SLAM! hahaha
    Anyone else feel this way about this trick?
    2017 Axis T23
    2014 Supra SC350 Sold
    2012 Outback V - Sold
    Sep 2015
    UT 6000'
    Let's see the video! How do you have your SC weighted? I just got mine and haven't tried anything wake yet.
    DFTR Josh
    Supra/Moomba
    www.marine-products.com (Discount Code: DFTR-1)
    Apr 2013
    Richmond, VA
    ahh - weighting the SC:
    wakeboarding:
    Back compartments filled: 1000lb each side (250lb hard + 770lb flex)
    Middle hard tank filled: 400lb
    IBS filled 500lb.
    Fat sac or fat friends sit up front: need at least 300 and prefer 500lbs in the very front to get that nose down.
    wakeplate: down to plane it and up to ride it.
    Surf:
    same set up except drain 50% of weight from the offset side in back.
    2017 Axis T23
    Apr 2013
    Richmond, VA
    i forgot to mention on the surf set up....
    wakeplate 50%
    surf setting is skim. always skim -- barrell setting doesnt seem to work well.
    2017 Axis T23
    Sep 2015
    UT 6000'
    Let's see that wake! Can't say in UT (5600') mine will plane with that weight. So is this everything stock then add the bow weight? I was wondering how the true stock weight is and you might have helped.
    DFTR Josh
    Supra/Moomba
    Apr 2013
    Richmond, VA
    I got the video but it's in the apple movie format so I have to figure out how to get a link and post it.
    On my first try i just barely slipped out after making a clean handle pass so on my second try I know im going to make it and then I got throttled. This one is cruel.
    2017 Axis T23
    Sep 2015
    UT 6000'
    Got my first session behind the SC today and WOW! I could only go 85% rear and 100% front but the wake was legit. Can't wait to play a little more with this wake.
    DFTR Josh
    Supra/Moomba
    Apr 2013
    Richmond, VA
    I saw the pics -- looks great - plus you have the big engine and the new surf assisted planing so you should be able to get up and moving nicely.
    2017 Axis T23
    Sep 2015
    UT 6000'
    Quote Originally Posted by JASONZ View Post
    The launch feature is night and day with getting on plane.
    DFTR Josh
    Supra/Moomba
    Feb 2011
    Skiatook Lake Oklahoma
    I'd be happy to help ya on the toe 3. Post up some video.
    The thing I see the most is spinning too fast and over rotating. That's why so many riders skip toe 3 and go straight to toe 5.
    Todd
    2017 SUPRA SA450
Tags for this Thread
