Results 1 to 8 of 8
    Jul 2016
    Default Swim platform issue can someone tell me if I have a problem?
    I bought a new to me 2000 kamberra today. I didn't notice it before I bought the boat but when I got it home, I was getting in the boat (out of the water). And when I put weight on the swim deck I noticed the transom somewhat flex. Just around the mounting brackets. Is this normal when the boat isn't in the water? Or do I have an issue? I thought about adding some support bars more to the outer part of the platform. But I would rather know if I have a problem or not to begin with.
    Jul 2016
    Nobody has an answer? I went and looked at again today and it definitely is moving just right at the mounts. Almost like the backing plate isn't big enough. But I can't see anything from the engine bay. Without having to really start tearing stuff apart
    Portland Oregon
    Stick this in google, start there.
    "moomba transom swim platform"
    Lots on this.
    Here's the hole I cut, more in my thread "pumps in!!"
    -Jake
    Jul 2016
    Ok that's about the only variation of the wording I haven't tried to google. I've been reading As much as I can. The whole engine bay of my boat it finished out in carpet and stuff though so I'm kind of blind unless I really start ripping into it. Thanks for your response
    Portland Oregon
    Quote Originally Posted by Blazeshoe View Post
    Yes you pull the carpet back, cut the floor, and carve out some foam. I just put spray foam back in and shaved it flush with the floor, and glued the carpet back down with DAP contact cement.
    -Jake
    Jul 2016
    Ok so I went out and looked a little closer today top bolts were way easier to get to than I had thought. What did you use to cut the access hole? And my top bolts only had two really small washers, there was not a back plate of any sort. Is that normal?
    Portland Oregon
    My supra had plates but I made some larger plates. I used a multi tool to cut the holes.
    -Jake
    Jul 2016
    Man I really appreciate your help a lot. I'm going to build some plates. I'm also going to build some for the bottom I think since they just thread into the boat not. I'm actually a lot more handy than this post makes me sound lol. Thanks man I sure appreciate it
