Results 1 to 7 of 7
07-18-2016, 05:57 PM #1Junior Member
- May 2016
- 24
2016 Moomba Mojo Ballast hose diameter
Does anyone happen to know the diameter of the ballast fill/drain hose in the rear lockers? I recently installed the flyhigh 1450 lb bags in the rear lockers and one of the hoses is constantly in a bind because the hose is very short and keeps popping off the bag. Looking to get a couple longer hoses to try to prevent this from happening but I forgot to measure the width of the hoses. Thanks
07-18-2016, 09:43 PM #2
I think they are 1 inch
2016 Mojo
2010 Moomba LSV-Sold
07-18-2016, 10:39 PM #3Senior Member
- Mar 2015
- 134
2015 Mojo Surf Edition
1100 rear lockers
400+ under each rear seat
700 stock center
950 ibs
autoflow 2.0 surf tab upgrade
FAE
07-18-2016, 11:47 PM #4Junior Member
- May 2016
- 24
It's the one on the bottom in the back corner
07-19-2016, 09:40 AM #5Senior Member
- Mar 2015
- 134
Then you can try what I said and see it that helps.
I had this issue too. The fitting would pull out of the bag if the bag wasn't perfectly positioned. Tightening up the fittings and removing the floor clamp has eliminated the problem. I still check the bags while filling to ensure no problems.2015 Mojo Surf Edition
1100 rear lockers
700 stock center
950 ibs
FAE
07-20-2016, 03:16 PM #6Junior Member
- May 2016
- 24
Thanks for the info. That's a good idea. Mine also had the stainless clamp on the floor. I went ahead and ordered a little longer hose so I'll try both
07-20-2016, 10:03 PM #7Senior Member
- Mar 2015
- 134
Good luck.
Mine had a black plastic band around the hose held down to the floor with a stainless screw.2015 Mojo Surf Edition
1100 rear lockers
700 stock center
950 ibs
FAE
