Results 1 to 3 of 3
Thread: Fuel problem
07-16-2016, 09:07 PM #1Junior Member
- Jul 2016
- Oregon
- 1
Fuel problem
I have a '03 mobuis dd fuel pump does not come on when you turn the key. After banging head for hours and taking apart wiring traced to the temp. sensor put in a used one and fired right up. so after putting in a new one back to same original problem. Put in the used one and nothing. boat just cranks no fuel. Any help would be great.
07-17-2016, 05:47 PM #2Senior Member
- Aug 2006
- Millington TN
- 204
Is your engine carbureted or fuel injected?
Larry Engelbert
Indmar Marine Engines
"Power to the Sport"
07-17-2016, 09:00 PM #3
Put a test light on the two wires on the fuel pump turn the key on and see if the light comes on. If the light comes on and you don't hear the fuel pump come on I would think it would be a bad fuel pump
Sent from my SM-G900V using TapatalkLast edited by Jceclipse01; 07-17-2016 at 09:05 PM.
"You spend most of your life, looking for the adult that you are... then you spend the rest of your life looking for the child that you were."
98 boomerang sold
04 outback lsv
