Results 1 to 10 of 10
    Apr 2005
    Madison, WI
    Default Adding Trailer Backup LED's
    I searched the forum and didnt see any information of someone adding backup LED's to their Moomba trailer. Id like to add them and am torn between cutting the holes for a standard oval white LED towards outside of the trailer or surface mount a 12" LED strips towards the inside. Anybody have these already installed? Share photos?
    Jim Hagen
    Madison, Wisconsin
    facebook.com/signedgewraps
    2011 Moomba Mobius LSV - Exiled
    2002 Moomba Mobius LSV - Sold
    May 2013
    Vancouver WA
    Are you talking about the LED reverse lights on the trailer? Mine already has those. or are you talking about something different???
    www.TraysonsToybox.com
    Jim - have had similar thoughts but no room for cutting holes. Surface mount of some sort would be viable or possibly swap out one of your existing tail lights and rewire it for a reverse light would probably be easiest. Like Trayson's setup.
    I've thought of adding a smaller surface mount reverse/white light on the bottom edge of the rear fender - keep it concealed but still useful to let me know when the tires are about to hit something down low.
    May 2013
    Vancouver WA
    FWIW, mine came factory that way, I'm pretty sure.
    Mar 2016
    Leduc, Alberta, Canada
    Sent from my SM-G935W8 using Tapatalk
    2016 Craz
    May 2013
    Vancouver WA
    Quote Originally Posted by deckwork View Post
    good solution for getting the tie down straps on the outside of the auto flow 2.0 plates.
    Mar 2016
    Thanks was concerned about the steel being thin but seems to work worst case will have to weld some plate in behind and better than relying on platform to hold boat to trailer
    Sent from my SM-T330NU using Tapatalk
    2016 Craz
    My brother added a mini bar to his fishy boat trailer. I might look into one of these.
    I read that completely differently . . .
    Apr 2005
    Madison, WI
    After discovering that mice have made a meal of the trailer wiring, Im going to buy a new wiring harness from Boatmate that includes wiring for backup lights. Harness is $75. Thanks for the photos and input. Ill update as the project happens.
    Jim Hagen
    Madison, Wisconsin
