Results 1 to 10 of 20
Thread: No sound from one tower speaker
07-12-2016, 04:10 PM #1Senior Member
- Jul 2009
- Marquette, Michigan
- 141
I have a set of exile XM9's. No sound is coming from one of them. I've tried switching them back-and-forth from side to side, the good one always works and the bad one never works, seemingly eliminating the mounts as the problem.
I sent the one back to exile. They checked it out and found no problems. But when I got it back on my boat still nothing. Anyone have any ideas?
Sent from my iPhone using Tapatalk2019 Moomba Mojo
07-12-2016, 04:29 PM #2
This will be easy. Go purchase, @ Radio Shack for example, a basic mono 2-pole 1/4" female phone jack. Wire up the two poles to an amplifier channel using a new test length of wire and plug it onto the speaker 1/4" male phone plug . Bypass all else. This conclusively tests the speaker in isolation. Independent of the tower harness. Independent of the quick disconnect.
07-12-2016, 04:50 PM #3Senior Member
- Jul 2009
- 141
That's exactly what they did at Exile and it worked fine. It kind of has to be on the tower side, but the one speaker works fine on either side.... Puzzling.
07-12-2016, 06:34 PM #4
Next you have to measure that the male 1/4" post on the speaker connector is precisely in the middle at the tip and not warped slightly to one side. Keep in mind that one contact point is a full inch away from the base of the post so the slightest imperfection can be magnified. It is possible to have a little wear and tear so that one particular male and one particular female connector no longer mate up perfectly. Also try spinning the non-working speaker 180 degrees and see if you get momentary contact. Try loosening, rotating and remounting the collar 180 degrees.
07-12-2016, 06:43 PM #5Senior Member
- Jul 2009
- 141
2019 Moomba Mojo
07-12-2016, 07:42 PM #6
The diagnostic assistance will only be as good as the accuracy of the information you have provided. And I'm assuming that everything you've stated thus far is very accurate. From everything you have tried and stated thus far, it points to one issue.
While it seems that you have already tried everything, I would follow through from the beginning and make all these tests for yourself.
07-12-2016, 09:05 PM #7Senior Member
- Jul 2009
- 141
Yup. I'll keep working at it. Thanks for the help, David.
07-13-2016, 08:41 PM #8
Dumb question. Are all Rca connections and speaker wires plugged in good? I ask this dumb question from experience.
Sent from my iPhone using Tapatalk2017 Supra SA
07-13-2016, 09:41 PM #9I've tried switching them back-and-forth from side to side, the good one always works and the bad one never works, seemingly eliminating the mounts as the problem.
07-14-2016, 05:36 AM #10Senior Member
- Jan 2016
- 149
Do you have a Kicker Dual Zone control by chance?
