Results 1 to 10 of 25
Thread: Dual batteries worth it?
07-06-2016, 09:05 AM #1Senior Member
- May 2010
- Muskoka, Ontario
- 427
Right now we have the dual battery option from the factory. We are going to be swapping batteries because it looks like ours are worn out. Since we have a cottage and never run anything with the key off for extended periods of time is there any benefit of a dual battery setup?
07-06-2016, 10:28 AM #2
Yes.......
Sent from my SM-G900V using Tapatalk2017 Centurion Ri237
2013 Supra SA450 - Sold
2006 Mobius LSV - Sold
2004 Stingray 190LS - Sold
07-06-2016, 10:50 AM #3
I do run my stereo for extended times off one battery and never had an issue. Ski boats don't like weight and they don't have a place for one. Try it on one battery for a time and see if you have any issues. The battery does need to be maintained and replaced when it is evident that you have hard cranking. I keep a battery tender on it when not in use.
1998 Mobius
310 HP PCM
SOLD
07-06-2016, 12:02 PM #4Senior Member
- May 2010
- Muskoka, Ontario
- 427
not to be rude but what kind of answer is that? I've always had 1 battery in the boats we have owned before and never had an issue. I can see if you go out on the lake and run a stereo while floating or do stuff with the engine off, but if you don't do that what benefit? When the engine is running the batteries are being charged and the draw is from the ALT unless you are drawing too much then it resorts to the battery but we don't have a stereo that would pull that.
07-06-2016, 12:11 PM #5Junior Member
- Jul 2015
- Manchester
- 26
Of all the toys & accessories that I've fitted to my boat the second battery & blue sea add a battery with charge relay has to be the most essential. if your alternator is playing up & you havnt realised or you stop to let the kids play & run the battery below its minimum cranking out put you can always relay on your cranking battery or pair them up to get started & back to the jetty, it gives you that extra security. definitely worth the money.
07-06-2016, 12:35 PM #6Senior Member
- Jan 2016
- 149
I second sivs1's answer.
YesLast edited by mazzyel2162; 07-06-2016 at 12:39 PM.
07-06-2016, 02:17 PM #7
07-06-2016, 04:04 PM #8
the benefit is pretty straightforward in your case. You have a backup battery in case your primary battery fails.
So you're the only one that can answer the question if the possibility of getting stranded one day + the cost of lost boating fun from downtime while you get a new battery is worth the price of a battery, battery box, perko switch, and some wiring.
You said from the get-go that you don't use your battery like many of us, so it's not worth addressing the reasons why we do it.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
07-06-2016, 05:21 PM #9
07-06-2016, 05:46 PM #102008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
