Results 1 to 9 of 9
Thread: Vibration when surfing
06-27-2016, 04:03 PM #1Junior Member
- May 2016
- 5
Hello,
New to V-drive's and forum. Have a 2005 LSV. While surfing there is a vibration that is very apparent to everyone in the boat. Its tough to locate where its coming from . My question is there a common bearing that needs replaced on these v-drives? Boat has 265 hours on it. Vibration goes away if you speed up or slow down.
TIA, cameron2005 Moomba LSV
06-27-2016, 04:11 PM #2
What prop are you running? There were a few OJ props around 14" in diameter that would present a growl at certain RPM's. If you have access to another prop you may want to swap out and see if you get the same result.
06-27-2016, 04:52 PM #3
agree with Kane check prop or swap and see if it goes away. are you sure it is not cavitation?
2015 Supra SG 450 Fire Red Metallic
Wetsounds and MMATS
2015 Mojo
2014 LSV
2006 Tahoe Q4sf
06-27-2016, 04:54 PM #4Junior Member
- May 2016
- 5
06-27-2016, 05:21 PM #5
my old supra had the oj 13x17 and it growled a ton so was not limited to the 14" variants.
switched to acme 1235 and all went away.'06 Supra Launch 20SSV-gone but never forgotten
06-27-2016, 11:13 PM #6Junior Member
- May 2016
- 5
Have the oj 13.7x17.25 prop. I will try to swap out and see if the vibration goes away. Any prop recommendations?
2005 Moomba LSV
06-28-2016, 03:01 AM #7
if you have trailer clearance acme 1235 or 1273 , if you don't have to much room acme 1433
Wetsounds and MMATS
2015 Mojo
2014 LSV
2006 Tahoe Q4sf
06-28-2016, 08:00 AM #8
It really depends on a lot of factors. The amount of weight you usually run, the size of your typical crew, elevation of your home lake, whether anyone ever slalom skis behind the boat, etc. Call these guys and tell them about your usage and tell them you want the best ACME prop for your application. They will steer you right.
http://www.nettleprops.comMy Mom said I'm not allowed to get wet!
06-28-2016, 08:18 AM #9'06 Supra Launch 20SSV-gone but never forgotten
