Results 1 to 7 of 7
    Apr 2014
    Owensboro, KY
    Default Boat won't go over 3000 rpms?
    Anyone ever had an issue where their boat won't go over a certain amount of Rpms? After being out all day and after a boarding session the boat would go to 2800-3000 rPMs no matter how much throttle I gave it?
    2008 340 EXT Cat engine
    May 2013
    Vancouver WA
    Quote Originally Posted by JHutch View Post
    Yes, I had this happen, I have the same engine as you. The engine is going into limp mode. 3000 RPM's is the magic number. Take a look at your oil pressure gauge and I'll bet money it's low. and I'm also betting that the reason it's low is because you're low on oil (probably 3 quarts or more low). Check your oil, top off your oil, and look for any leaks.
    www.TraysonsToybox.com
    Jul 2013
    Wisconsin
    When was the last time you changed the plugs?
    2008 LSV. 1100 rear sacs and IBS. ACME prop is next
    Ronix One w/ Parks bindings
    Apr 2014
    Owensboro, KY
    Checked the oil. It was full. As far as I know the plugs are original, boat has 220 hours.
    Sep 2009
    Langdon ND
    Fuel filter, just had the same thing happen on my 06 LSV. Took off the filter and could hardly blow through it.
    May 2015
    Woodlands/Conroe, TX area
    It goes into the limp home mode for almost any error. I had it do the same due to a fuel filter as mentioned above.
    2008 Moomba Outback DD resurrection
    Jul 2013
    Wisconsin
    I'm no expert, but I think you may have a hard time specifically diagnosing what is wrong without just replacing things and seeing if it fixes it. I suggest starting at the least expensive. For me it sounded like it was missing so I guessed the plugs were bad and ended up correct. Runs better than ever before so at 220 hrs it can't hurt to just change the plugs, filter, and other suggested maintenance items first.
