Results 11 to 17 of 17
07-04-2016, 07:38 AM #11Senior Member
- Jan 2016
- 149
correct. The speedo calibration knob is under the dash. Simple, simple simple thing to do.
07-04-2016, 09:42 AM #12Banned
- Feb 2014
- My Moomba Lives in Eagle River, WI - We Live in Chicago
- 225
07-05-2016, 01:09 AM #13Senior Member
- Jan 2014
- Kelowna, BC Canada
- 426
What is the name of the app to DL that gives you an accurate speedo reading? I have a feeling mine might be off and would love to be able to verify.
2014 Black/White Mojo
345HP Surf Motor
1235 Prop
Autoflow 2.0 Upgrade
1100# FlyHigh Rears
650# IBS
4 x Exile SXT9q's w/ Exile 30.2 amp and Exile ZLD controller
Exile Javelin Amp
10" Rockford sub
07-05-2016, 07:53 AM #14Senior Member
- Aug 2015
- Ohio
- 240
07-05-2016, 09:02 AM #15
Speedo calibration help for '15 Mojo
I use the navionics app. It is a must for new lake or evening runs. It has gps speed.
Sent from my iPhone using Tapatalk2017 Supra SA
07-05-2016, 09:18 AM #16
Shane
2016 Supra SE
EXILED
6 XM9 Tower
6 Wetsounds XS650 Cabin
1 XM 15.4
XI 1500.1
2 MX 30.2
Wetsounds 420 EQ
EXILE Blue tooth EXBT4
Blue LEDs
07-14-2016, 03:03 PM #17Junior Member
- Aug 2015
- 20
Sorry for the delay haven't been on here for a while. So on my '15, as far as I can tell there is no "knob" for the analog speedometer, i looked everywhere and didn't see anything. The digital speed and cruise control are controlled through the display menu under "paddlewheel offset." Mine was 2-3 MPH off. It's pretty hard to do by yourself so make sure you have someone with you to drive while you're changing the offset settings to get the speed right. I had to cycle back and forth like 15 times before i had it calibrated - just synced it up to the iphone - downloaded a free "boat speed" app. Honestly I never even look at the dial gauge speedometer so I'm not sure if it affected that at all.
