Results 1 to 10 of 17
Thread: Exile EXBT4 and Sony CDX-M60UI
06-20-2016, 07:13 PM #1Junior Member
- Jun 2015
- Fargo
- 29
Has anyone been able to get the Exile Bluetooth adaptor to work with the Factory Sony CDX-M60UI and 2 Kicker amps?
This is a factory setup for a 2013 Moomba LSV. It doesn't appear there is a place to plug in the RCA cables from the EXBT4 into.
Thanks!2023 Craz
2013 LSV
06-20-2016, 08:45 PM #2
There is a bus in on the back of the unit you should be able to use , it's on my to do list but have not gotten to it yet, it's diagramed in the manual
06-20-2016, 08:45 PM #3Member
- Sep 2015
- Georgia
- 76
06-20-2016, 11:12 PM #4Junior Member
- Jun 2015
- Fargo
- 29
I tried the bus in and the two black Rica cables, neither one worked. Called Exile for support and they said it won't work with that head unit. Recommend purchasing their ZLD which is $300.
2023 Craz
2013 LSV
06-20-2016, 11:36 PM #5
06-21-2016, 10:30 AM #6
An EQ is not a solution if you want to maintain your remote control functionality.
There have been three separate Sony model #s supplied of devices that are specifically intended to open up the menu and open up the RCA input on the rear of the chassis of a Sony UniLink source unit. At least one of these three devices solve the issue.
06-21-2016, 01:23 PM #7
I use an exile eq and Sony head unit in my 14 mojo. One input on eq is Bluetooth into eq. The other input is head unit. I can use both remotes to change volume and radio stations. There are times like in a storm that old fashioned radio is not bad to have.
Sent from my iPhone using Tapatalk2017 Supra SA
06-28-2016, 11:56 AM #8Member
- Sep 2015
- Georgia
- 76
Have the solution! Bought 3.5mm male (aux in) to rca female adapter at fry's for about $3 and a 3.5mm male to female 6' extension. Plugged the extension into the unit and ran through grommet already there for USB line. Behind I connected adapter to extension and then into exile BT. Already had connected BT to power and ground. It works great now.
Only needed extension to make it look clean since rca adapter was only 6 inches long or so. Can try and take pictures of packages if it would help. Hopefully this will work for you too. So much easier to keep phone at help or pass it around.
Sent from my SAMSUNG-SM-G900A using Tapatalk
06-28-2016, 01:51 PM #9
06-28-2016, 02:13 PM #10
it works, sure, but kind of the long way around, considering Sony makes a simple and cheap device that unlocks those BUS Audio In inputs for adding such AUX devices. .
