Results 1 to 8 of 8
Thread: Fuel additive
07-12-2006, 07:00 PM #1Member
- Jan 2006
- 30
Fuel additive
Manual states something about using a fuel additive if your boat sits idle for a week or more. Does anyone use this stuff?
07-13-2006, 08:23 AM #2Senior Member
- Mar 2005
- t-town
- 718
Replying to Topic 'Fuel additive'
matman, i think they are referring to stabil.
07-13-2006, 10:15 AM #3Member
- Jan 2006
- 30
Yes...it's stabil, anyone use this and if so where do you get it?
07-13-2006, 10:31 AM #4Senior Member
- Dec 2005
- Ontario
- 531
Hey Matman, if you need this stuff you arent using your boat enough... you need to get your priorities straight...lol
Just kiddin, you should be able to get fuel stabilizer just about anywhere that sells automotive stuff ie. oil, injector cleaners, etc..2005 Moomba Outback
07-13-2006, 10:36 AM #5Member
- Jan 2006
- 30
Smrt...doesn't this raise your octaine rating too? boats been diesling and it's been suggested its the gas, I've used 87 but now use 89...still diesles
07-13-2006, 10:40 AM #6Senior Member
- Dec 2005
- Ontario
- 531
I was told never use anything less than mid grade (so 89) It could have caused some build up. From reading the board ive also seen that it isnt abnormal to get water or condensation in the gas. I would use the stabilizer and see if this fixes the problem but also top it up with high grade fuel too this will have a cleaning effect that hopefully would solve your problem.
2005 Moomba Outback
07-13-2006, 10:43 AM #7Member
- Jan 2006
- 30
Thanks...I give er a try
07-13-2006, 09:42 PM #8Senior Member
- Feb 2004
- 168
If you think you may have moisture in the fuel add a can of HEET.
where is the fuel filter?
By marchina in forum General ChatReplies: 7Last Post: 09-02-2008, 07:28 PM -
Fuel Filter?? Lack of power on fuel throttle
By slalomskier in forum Service & RepairReplies: 8Last Post: 08-02-2007, 03:52 AM -
replace fuel filter with fuel water separator
By vansolo in forum Service & RepairReplies: 4Last Post: 05-04-2007, 12:17 AM -
Fuel Tax Refund for Boat Fuel
By Will Watters in forum Boat OwnersReplies: 10Last Post: 05-03-2006, 01:14 AM -
Fuel
By Bammer in forum Boat OwnersReplies: 3Last Post: 11-26-2002, 09:57 PM
