Results 1 to 9 of 9
07-12-2006, 06:54 PM #1Member
- Aug 2005
- California
- 35
Missed my service appt. Now what?
I missed my 20hr service appointment, and the dealer doesn't have another appt. until late Aug. What can I do to keep everything ok until then?
P.S.- My service was going to cost 400.00... Is that about right, I thought it was an oil change and carb adj.???2005 Outback- Silver Gelcoat White Accent
07-12-2006, 08:59 PM #2Member
- Jun 2006
- 40
Replying to Topic 'Missed my service appt. Now what?'
Just had mine done and it was $220.00 with a $50.00 discount since I bought the boat there.
$400.00 sounds high!
07-13-2006, 12:24 AM #3Senior Member
- Jul 2003
- 340
Same here. Mine was around $200.
07-13-2006, 09:33 AM #4Member
- Aug 2005
- California
- 35
But missing the service... is that bad? I have checked the oil and it is still clean.
07-13-2006, 10:02 AM #5Senior Member
- Dec 2005
- Ontario
- 531
Jrich,
Its very important to at very least change the oil. when it comes with the initial oil it has a detergent in it that cleans any of the dirt and debrese from the manufacturing process out of your engine.
As for 400.00 that is rediculous.. As you may have read I am still feeling burned for having to spend 300.00 on mine. Who is the dealer that is charging 400.00 for teh 20 hr service.
It is worth getting the boat checked over however an oil change should cost no more than 150. maximum so what is the other 250.00 for.
As far as Im concerned some dealers take advantage of new boat owners and the fear that something could be wrong with the boat that you just dropped a hugs chunk of change on. As you will see from looking around the board not every dealer will treat you this way. If your dealer insists on gouging you then find another place to get it serviced that services or even sells inboard boats.
let us know how it turns out for you
Good Luck!!
Jay2005 Moomba Outback
07-13-2006, 10:05 AM #6Member
- Aug 2005
- California
- 35
Jay,
Thanks for the guidence. I will change the oil this weekend.2005 Outback- Silver Gelcoat White Accent
07-13-2006, 12:32 PM #7Member
- Aug 2005
- California
- 35
Update!!
I called my dealer here in CA and he said the service is now only 350.00 which includes
1. Oil change Filter
2. Fuel Filter
3. Tranny Fluid Change
4. A carb adjustment that I had to request.
5. Check bolts and clamps for tightness
That's it... 350.00 seems like a lot of money for 40.00 worth of parts.
So I told him that I missed the appointment for 20hrs, and he said as long as the oil is clean then I'm good until 40-50hrs. Go figure?2005 Outback- Silver Gelcoat White Accent
07-13-2006, 12:44 PM #8Senior Member
- Jan 2005
- Alabaster, Alabama
- 143
My dealer thought it was crazy to have a boat for 20hrs and spend $400.00 on the service. He charged me $100.00 which included the oil change and the other related items.
07-14-2006, 03:14 AM #9Senior Member
- Jul 2003
- 340
That 20 hour should also include checking the alignment of the shaft as well. They need to make sure the motor hasn't shifted any on the mounts as they settle in and thrown the alignment off.
50 Hr Service
By Pike in forum Service & RepairReplies: 4Last Post: 07-31-2007, 12:24 PM -
20 Hr Service
By Pike in forum Service & RepairReplies: 28Last Post: 06-28-2007, 09:20 AM -
20 hr Service
By TN_Boarder in forum Service & RepairReplies: 11Last Post: 09-28-2006, 12:07 PM -
EZ Cruise - Factory Missed
By 06 OB LSV in forum General ChatReplies: 2Last Post: 05-25-2006, 12:22 PM -
XLV oil service
By chpprpilot in forum Service & RepairReplies: 1Last Post: 07-12-2005, 04:01 PM
