Results 1 to 8 of 8
    Aug 2015
    South of Chicago IL
    Default Isolating head unit from ignition switch
    Has anyone isolated the head unit "ignition/power on" from the key? I am very electrically skilled but if someone found the easy way without tearing apart the CB distribution I would like to know. I am sick of loosing toons every time I shut down to switch riders/ or have jumpers. Head unit is fusion MS-RA205 on 2015 mondo. Thanks
    Work to live!!
    2015 mondo
    Aviator tower
    Auto flow
    94 rinker 180 gone
    take the wire off the ACC terminal and wire it to a rocker switched B+
    Aug 2015
    South of Chicago IL
    Thanks. I will do that and report back.
    Work to live!!
    2015 mondo
    Aviator tower
    Auto flow
    94 rinker 180 gone
    Aug 2015
    South of Chicago IL
    No terminals to take wires from. Need special insert/removal tools to pull terminations from cb blocks. Guess it is a cut n splice job. I was hoping to just pull n swap some connections. No joy there. Going to use spare acc switch to run power for tunes n swap cb to handle load. No quick n easy fix.
    Work to live!!
    2015 mondo
    Aviator tower
    Auto flow
    94 rinker 180 gone
    Never seen a key switch on a boat that required special tools to remove a wire. They either have a typical male spade or a round eye post and screw. You have a B+, RUN, CRANK and ACC.
    Feb 2006
    Birmingham
    I spliced the power wire into the positive power block under the dash. Now as long as the batteries are on the radio has power. Only issue is you have to remember to hit the power button when docking temporarily. When you cut your batteries off the unit goes dead for longer term docking/storage.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Aug 2015
    South of Chicago IL
    I ended up doing something very similar. Only I went through an unused ACC switch. This way I can power down without disconnecting batteries.
    Work to live!!
    2015 mondo
    Aviator tower
    Auto flow
    94 rinker 180 gone
    Default Re: Isolating head unit from ignition switch
    Thanks guys, was just wondering how to fix this..lol
    2006 Moomba Mobius LSV - Sold
