Results 1 to 8 of 8
Thread: SC warranty replacement question
06-08-2016, 10:15 PM #1Senior Member
- Jan 2014
- Kelowna, BC Canada
- 426
Hey guys ... so my old Sony head unit bit the dust and it was replaced under warranty by SC. It was the Cdx-m60ui. I now have a brand new MEX-M70BT in my hands which is great ... but I was told by a Sony rep that only the older model Sony ead units would work with the remote that is in the 2014.
I would be very surprised if SC would send out a replacement unit that didn't work with the existing remote ... but was wondering if anyone here knew? I don't want to book my audio guy and then have him tell me it isn't compatible.
Thanks2014 Black/White Mojo
345HP Surf Motor
1235 Prop
Autoflow 2.0 Upgrade
1100# FlyHigh Rears
650# IBS
4 x Exile SXT9q's w/ Exile 30.2 amp and Exile ZLD controller
Exile Javelin Amp
10" Rockford sub
06-08-2016, 10:22 PM #2
I'd be willing to bet they are unaware the two do not work together.
I would reach back out and provide them the information the Sony rep provided you.
You mentioned booking your audio guy ... if it's warranty work, is there a reason the dealer isn't making the swap?2016 Moomba Mojo
2006 Supra 24SSV - Traded
06-08-2016, 10:48 PM #3I would be very surprised if SC would send out a replacement unit that didn't work with the existing remote
What will work however, is the actual remote buttons, if the head unit has the 3.5mm steering wheel control input. If the remote is the larger LCD remote, you lose the display.
06-08-2016, 10:49 PM #4Senior Member
- Jan 2014
- 426
Dealer said it was parts only. Swap would cost me the standard rate per hour. I have a bunch of other things lined up so my audio guy was going to do the swap in the process of tackling the other stuff.
Thanks I emailed back to my dealer to find out about compatibility.2014 Black/White Mojo
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
06-08-2016, 10:51 PM #5Senior Member
- Jan 2014
- 426
06-09-2016, 02:51 PM #6Senior Member
- Jan 2014
- 426
So turns out we are SOL when it comes to the remote. Just got word back from SC on whether the new deck is compatible with the existing remote and the answer is NO. It will function but no display as stated above:
Jay, Contacted the MMS Warranty department and this is the response I got.
"I talked to Skiers and when Sony discontinued the original deck the replacement one they supply is the one you have, and according to what Sony told Skiers last fall there is no remote that displays for that deck and that the original one will function properly but not display. Skiers have run into this before but due to no proper remote available from Sony this is all they can do"
Not really too impressed with that at all. Since when do you have a warranty replacement where the new part being installed didn't actually work with another fairly vital component of the stereo system? Now if I want to have it operating properly as it used to ... I need to shell out extra $$ for a compatible remote.2014 Black/White Mojo
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
06-09-2016, 04:37 PM #7
I know it's not optimal but can you find a replacement of the deck you need on ebay or Crutchfield to swap in? Sure it wouldnt be more than 100 bucks or so and you could just sell the deck they sent you. There are always new in box discontinued stereos floating around. I had to do this on my last boat to keep the remote working that I already had (the remote was custom mounted and would have looked like crap to remove/replace).
06-09-2016, 06:46 PM #8Senior Member
- Jan 2014
- 426
345HP Surf Motor
1235 Prop
1100# FlyHigh Rears
650# IBS
Exile Javelin Amp
10" Rockford sub
