Results 1 to 10 of 16
Thread: 2016 Craz General Questions
06-06-2016, 04:36 PM #1Junior Member
- May 2016
- 4
So, new to forum and wakesurf/wakeboarding boats.
We recently bought a new 2016 Craz, surf edition and didn't get a chance to go out with the dealer to explain all the gadgets/tricks so I figured I'd ask the questions I had on here.
These might sound like dumb questions but I'm new to the scene.
1.) Do I need to be under a certain speed while a fill/empty ballast?
2.) The center hard tank, is there a way to check if this is empty?
3.) When I empty all the bags and the pumps seem to be sucking air there is still a little water in them, is this normal?
4.) For the AutoFlow 2.0, when someone says they set the plate to 65% to surf starboard, are they meaning they set the port plate to 65%, as this is the plate that deploys when you flip the switch to starboard?
We can go ropeless surfing but it seems like the most push is very close to the boat. I can't seem to get the wave any longer, it's only clean real close to the boat. Had both rears full, front at 65%, wake plate at 3/4, 55 port/75 starboard for auto flow settings. When I fill the front more it seems like wave height/push is seriously affected.
FWIW, anything under 10' depth the wave decreased significantly.
06-06-2016, 11:18 PM #2
Yes for filling keep it slow and empty you can roll any speed.
Never tried but where you put your mid plug you can check I guess.
My front empty's all the way, the back I have to lift up the ends to get completely empty and not risk burning the pumps.
Correct
06-06-2016, 11:44 PM #3
DFTR answered most of your questions. I am also really new to both the tow boats and wakesurfing, but each time we go out it gets better making little adjustments in both settings and skill best we found so far was rear full front at about 3/4 (hard full and bow about half) and wake plate at about a quarter deployed running 11 mph, this seemed to get me best rope less managed to drift quite far back and recover most of the time, as you mentioned it did seem to have most push close to boat the first couple of times I tried but each time out I seems like I can go further and further back at least this is what I have experienced.
2016 Craz
06-07-2016, 08:57 AM #4Junior Member
- May 2016
- 4
Thanks for the help, much appreciated!
06-07-2016, 09:05 AM #5
I speed up to 20 then go back to idle and fill and dran, Technically it doesn't hurt to fill or drain at speed.
Physically no, but they are pretty reliable on the dash guage. I always hit the drains on the ramp again to ensure everything is empty
Normal to have a little water left in the bags, this doesn't hurt anything. Add a 1 way check valve to the Vent line if you want them to drain 99%
4.) For the AutoFlow 2.0, when someone says they set the plate to 65% to surf starboard, are they meaning they set the port plate to 65%, as this is the plate that deploys when you flip the switch to starboard? Yes and YesMalo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-07-2016, 12:17 PM #6Senior Member
- Apr 2016
- 223
Deckwork, Luke2020 are you both running stock ballast?
2016 Craz
06-07-2016, 02:11 PM #7Junior Member
- May 2016
- 4
yes, stock i think 2,500 lbs
06-07-2016, 05:29 PM #8
06-07-2016, 09:06 PM #9
06-07-2016, 11:00 PM #10Junior Member
- May 2016
- 4
Any good recommendations on what to use to wipe it down with after each use? We're on a dammed river so water isn't to clean.
