Results 11 to 20 of 24
Thread: Bluetooth Receiver for Aux In
06-04-2016, 03:54 PM #11Junior Member
- Sep 2015
- 28
I struggled with this too and ended up with a RadioShack Bluetooth module that I put in the glove box and leave plugged into a cigarette light and the aux input. Works perfectly and was 35 bucks. I mount my phone on a suction cup at the helm so I can use navionics and I just run everything from there.
Sent from my SM-N920V using Tapatalk
06-04-2016, 04:00 PM #12
So you have a female RCA pair dangling out the back of the radio, right? If so those are for sure the RCA cables added to the AUX front input on the CDX-M60Ui. A stock 69Ui has no loose cables on the back.
Connect your BT adaptor there. Make sure it has power. Then make sure you can pair to it. It all should work. If not test it by connecting some other known-working source to that rear AUX connection to verify it is working.
06-08-2016, 08:43 AM #13Member
- Sep 2015
- Georgia
- 76
06-08-2016, 11:05 AM #14
06-08-2016, 05:44 PM #15
I had tried that on our old sony and it didn't work. I am intrigued by the usb bluetooth though, I wouldn't have guessed that it would work.
Sean
2004 MOOMBA Mobius LS
1987 Kawasaki JS-550 (What was I thinking?!)
2004 Kawasaki STX-12f
2002 Kawasaki STX-R (BrAaAaPp!?!)
2007 Kawasaki Ultra LX (shhh... it's got a vortech )
2001 Toyota Tundra (Long Travel Tow Vehicle )
Checkout my LED project here!
06-08-2016, 06:31 PM #16Member
- May 2015
- Grand Rapids, MI
- 54
We use this on our boat.
http://www.dx.com/p/lit-lsmy-01-blue...0#.V1icapD3arU
Works great for the price. There is a lag between pressing a button on my phone and the volume going up or down.2014 Moomba LSV
06-08-2016, 09:09 PM #17
The exile audio Bluetooth is really good. Hides away under dash and connects to rca inputs.
Sent from my iPhone using Tapatalk2017 Supra SA
06-08-2016, 09:41 PM #18
^^^^^ If the head unit has RCA inputs, which is the topic of this 2 page thread.
To the OP, heres what pops up if you google Sony BUS audio in http://www.crutchfield.com/S-WAk78uq...-For-Sony.html
Plug it in and the head unit thinks theres a CD changer there, BUS IN becomes active. Works great if you cant get any other method to work.
10-14-2016, 12:26 AM #19Junior Member
- Oct 2016
- 2
Guys, need help here. I bought the PAC Unilink Adapter For Sony to plug into the BUS in the back of the Sony - plugged in fine. This enabled the CD2 on the display, and the exile plugged into the back of the deck - all good. However, the sound quality through this channel is NOT good. I use the USB pigtail to connect my iPhone 5S and the music sounds amazing. But using same phone in bluetooth mode via CD2 = poor sound quality. What up? Am I going to have to replace the deck for one with bluetooth and ditch the exile? Any help greatly appreciated (hoping it may be a setting on the deck or something...)
10-14-2016, 08:23 AM #20
Cames,
The issue is that the BT receiver's output voltage level is too high for many head unit AUX inputs, which are obviously designed for the headphone level output of a music source. Its basically too strong of a signal. If the head unit has an adjustable AUX level, turn it down. Dont run your phone's volume past 80% and make sure the EQ is off or flat. Start there.
