Results 21 to 22 of 22
Thread: water in the bilge
07-17-2006, 07:02 PM #21Banned
- Oct 2005
- Durham, NC
- 649
Replying to Topic 'water in the bilge'
It is not grease the nut is packed with. If I recall correctly, it is kind of like rope with a waxy stuff impregnated in it. And you cannot access it from underneath. You have to access it from above. It is located just before the shaft penetrates the hull. And yes a pair of channel locks or a wrench should do it. They recommend tightening it with the boat in the water because there is an appropriate amount of drip you are aiming for. If I remember correctly, it is one drip every 30 seconds. You don't want to get it too tight, I assume the water is helping to lubricate the seal, and keeps the heat of friction of the shaft on the seal down.
07-18-2006, 02:02 AM #22Senior Member
- Oct 2005
- Central FL
- 791
LOL - um... NCSUMoomba... you may want to read the thread before you reply. Check 4 posts above yours.
-J
How much water should be left in the bilge?
By Laz in forum Service & RepairReplies: 6Last Post: 08-27-2007, 10:11 PM -
07 Mobious LS low temp and water in bilge
By h2oskierrick in forum Service & RepairReplies: 14Last Post: 04-03-2007, 04:19 AM -
Water in Bilge
By seanpatsdad in forum General ChatReplies: 1Last Post: 06-07-2004, 12:37 PM -
Salt Water/Brackish Water Use
By RickMcD in forum General ChatReplies: 2Last Post: 06-28-2003, 11:59 PM -
Unusualy high Bilge water level?
By Limeyrick in forum Service & RepairReplies: 4Last Post: 03-18-2003, 11:18 AM
