Results 1 to 7 of 7
Thread: 2013 digital cruise
05-25-2016, 12:18 PM #1
2013 digital cruise
My unit stopped measuring speed and the cruise itself will not turn on, everything else seems to be fine any suggestions. The regular speedo works fine
2013 LSV
2006 outback DD sold
2004 Stingray 180LX sold
05-25-2016, 01:06 PM #2
2013 digital cruise
Check your connections under the floor where it plugs in to the paddle wheel. And maybe behind the dash. Possibly a fuse.
Sent from my iPhone using TapatalkShane
2016 Supra SE
EXILED
6 XM9 Tower
6 Wetsounds XS650 Cabin
1 EXILE BIG 12 DVC 2000 watt in a ported box
1 XM 15.4
XI 1500.1
2 MX 30.2
Wetsounds 420 EQ
EXILE Blue tooth EXBT4
Blue LEDs
05-27-2016, 07:02 PM #3Member
- May 2015
- In the land of far far away.
- 31
What kinda boat do you have sharpshooter. Mine was giving me issues last year. It was a brand new 2015 moomba mondo. I lost water temp, speed and depth. The dealer gave me a new one cause it was on warranty. It lasted about 100ft off boat lift and quit again. Brought boat back to them last spring. They put in a sensor that comes of a supra I guess. Worked good all of last year. But id acting up again. Temperature fickrrs from -13f -66f.and the speedo will quit working once and awhile too.
05-27-2016, 08:31 PM #4
Sounds like the paddle wheel system is acting up. Do you tow long distances?
They say you should tape over the wheel so it's not spinning from wind turbulence.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-29-2016, 02:37 PM #5Senior Member
- Jan 2015
- Live: OP, KS...Boat: Shell Knob, MO
- 167
2013 digital cruise
I had an issue with my 2013 speedo last year but I believe both digital and analog speed went out. Ordered a new paddle wheel and it fixed it. Simple plug and play. Moomba guy I talked to mentioned the paddle wheel is water lubricated and should either be pulled or taped for long hauls and mine had just made a long journey.
2013 Mojo
05-30-2016, 07:09 AM #6
I would have thought if it was the paddle wheel neither speedo would work, my regular speedo gauge works fine, just not the one on the digital cruise control nor will the cruise turn on. Everything else seems to work fine on the digital dash. my boat is a LSV
2013 LSV
05-30-2016, 10:31 PM #7Member
- May 2015
- 31
Still having trouble with mine as well. I have another thread started on it. One guy figures I might have some moisture in my connector and to try some dielectric grease. So you could try that. I would agree with you it is likely not a paddle wheel issue if your regular speedo is working. It would be interesting to have a functional schematic of the system. To see what receives the message signal first from the paddle wheel module.
