Thread: Packing log jam nut size?
05-25-2016, 07:10 AM #1Senior Member
- May 2016
- West Milwaukee, WI
- 283
I'm hoping most moombas have the same size... I will be picking up the boat this weekend and heading straight for the lake. I saw that it is dripping too much (once per second). It would be nice to know I have the correct size wrench before I leave home. Does anyone know?
Also, I noticed that the floor behind the motor box has front to back seams. Is there a removable panel there that would give me better access to the drive shaft?
Sent from my Nexus 5 using Tapatalk2004 Mobius LS - hooked on footin'
Former tow: 1986 Chaparral 178 XL, 90hp Merc
First tow: 197x Glasspar Citation, 135hp Merc
05-25-2016, 07:57 AM #2
You will probably need 2 wrenches, u could use large channel locks or pickup plumber wrench
http://www.homedepot.com/p/HDX-Adjus...Q&gclsrc=aw.ds
http://www.pbase.com/mainecruising/stuffing_box
Not having owned a inline, I would expect a panel access as you describe.2014 Mojo Surf
2013 Mojo Sold
2010 LSV Sold
2002 OB LSV Sold
05-25-2016, 09:40 AM #3Senior Member
- May 2016
- 283
Ah, got it. That wrench looks like it would do the trick. Thanks for that tutorial link... illustrates the job very well.
05-25-2016, 07:51 PM #4
I thought there were changes in the floor since my 98 came out to get to the packing nut. I have to remove the floor which includes removing everything that sits on the floor which are the engine cowling and the rear panels. I would leave all that stuff at home and adjust on the water being careful not to get caught up in moving parts. Fortunately, I replaced the wax cord in 2004 and I have only needed one adjustment since then. Stay away from the wax cord as there are other alternative material that works much better.
1998 Mobius
310 HP PCM
SOLD
