Results 11 to 20 of 25
Thread: '14 LSV Sub box
05-25-2016, 04:37 PM #11
05-25-2016, 05:18 PM #12
The specs on the fa say it suited for a 1.3cu sealed box, would this be worth the effort with this sub/set up.. I'm asking most of this because I've never had IB or FA subs or setups and am new to it. My go to set up in other boats and my vehicles is a w6 or a w7 in the bow/locker or trunk and be done with it. Just don't have much experience trying to work with this stock sub position.
05-25-2016, 05:22 PM #13
KG I know you have done several boats, do you have an idea of ahow much room am I going to have to work with under the helm with that raised fiberglass footrest? (Boat is 3.5 hrs away @ the lake)
05-25-2016, 06:16 PM #14
I got this from your first post. Im not suggesting you put the bad woofer back in. However, going with the Kicker KM10, but the 2 ohm version, and constructing an enclosure is an option, depending on one still unanswered question.
You commented that you expected more from the 10fa? Obviously the new woofer is working better than the broke one, correct? My comment about a lateral move is specifically toward you not noticing a difference between the old woofer before it failed and the new woofer. reason being is because they both have the same cone area and still driven by the same 200W. You made no real upgrade in terms of output, just replaced a bad woofer.
I do not like running the 10fa in small sealed enclosure. Putting a true IB woofer in a small sealed enclosure is just opposite of placing a non-IB woofer in an IB alignment. Its not going to perform to its full potential. IMO, placing the xs-10 IB in a small sealed enclosure, will not get you what you seek. If you are looking for more bass, not just having a function woofer again, we need to fully understand the original setup. Right now, we know theres 2X the wattage left untapped.
Can someone clarify whether the facade is open at the top or a full wall?
05-25-2016, 06:31 PM #15
Open
Sent from my SM-G928V using Tapatalk2016 Moomba Mojo
2006 Supra 24SSV - Traded
05-25-2016, 06:33 PM #16
I'm not familiar with that year and the hump. I know mcdye has placed the ws all in one woofer above the hump. You could check it's external dimensions
05-25-2016, 06:36 PM #17
'14 LSV Sub box
Ok I never heard the km10 since I got the boat it has not worked. I have no reference there ,my references to expecting more was more directed to simply expectations of a 10" sub being barely audible except when boat is out of the water.
Sounds like I need to throw the new sub out and start a fresh with a $200 lesson learned
05-25-2016, 07:11 PM #18
Cut a new facade and ad a 2nd XS-10fa 4 ohm. Again, only speculating without knowing how that helm is constructed. Where is the subsonic, gain cross-0ver set? Is the sub level knob by chance connected but hidden? Is the sub output from the head unit turned down?
05-25-2016, 07:54 PM #19
I agree with what MLA stated. Even though the manufacturer gives you a sealed box spec, avoid the 1.3 cu.ft. scenario for an infinite baffle 10". Some computer program says it will get a 'Qtc' of XYZ and they may consider that an acceptable minimum. BUT, it simply will not sound good.
Can an infinite baffle 10" sound good? Yes, decent if all is executed correctly. But good execution for an IB subwoofer is going to be nearly impossible in a Moomba....or perhaps more trouble than the results you would get. A true IB 10" typically requires an enclosure of 2.25 cu.ft. up to infinite. That's far larger than a bass-reflex 10-inch and almost as large as a bass-reflex 12-inch including port displacement. So in this particular boat you have better options.
05-25-2016, 08:02 PM #20
Good woofer. Just a bad application is this case. Easy to do when you were simply following the factory or previous example.
Perhaps your dealer will give you consideration in an exchange for a woofer plus enclosure that will fit your boat better.
If not, there are many other brands where an IB 10" works far better, and that would be a good place to sell the driver for a minimal loss.
Classifieds on the MasterCraft forum comes to mind.
