Results 1 to 10 of 21
05-22-2016, 01:09 PM #1
material for amp and subwoofer trim panels?
I've seen it a lot in boat audio installations where there's a trim panel that's used. for example, I have a carpeted trim panel in front of my subwoofer box that's wrapped in carpet. I've seen people likewise build a trim panel and then wrap it in vinyl and cut out holes in it for the faces of their amps.
What material am I looking for if I wanted to build a trim panel? I'd think it'd need to be thin and not susceptible to water. Stuff like acryllic or hdpe would be too expensive. and it seems way more rigid than what I remember being on my subwoofer trim panel. I know there's got to be a "go to" material, but I'm not sure what I'm looking for.2008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
www.TraysonsToybox.com
05-22-2016, 02:26 PM #2
I use Starboard, 1/4" is relatively cheap.
In the past I've used 1/4 birch, like from Home Depot, but but the time you coat it with truck bed liner or similar, yada yada it's still not waterproof. Starboard is just so easy.2013 Outback V
05-22-2016, 04:34 PM #32008 Moomba Mobius XLV. Monster Cargo Bimini, WS Rev 410's, Polk Cabins, 3 Infinity Subs, PPI amps, WS420, Exile BT, upgraded ballast pumps, up to 3,500+ pounds of ballast, Blue LED's...
05-22-2016, 05:07 PM #4
Correcto-mundo, sir!
I've had great much buying scrap pieces from a plastics supplier.2013 Outback V
05-23-2016, 03:56 PM #5
KingStarboard is just one form of HDPE. But there are many types and grades of HDPE. KS is usually denser and used for visible applications because you can polish the edges to a gloss finish (ie: dash panels, hatches), which is not possible with a more porous HDPE. KS will be more expensive. You won't have any luck gluing or painting KS. In concealed applications, boat builders use HDPE versus KS. HDPE would be my choice for amplifier panels, and any other panel in which I am adhering carpet or vinyl.
The other very good option is a resin-coated cabinet-grade birch ply. If it's slightly spaced off the sole, it should last indefinitely.
I like 0.75" thick for most amp panel applications because it provides more screw depth. Thinner 0.50" is usually used on subwoofer cover facades.
Just no water-based MDF (even when treated) for these purposes. Although there are solvent-based composite materials such as Medex, Norboard, MDO, Extira, and more, that will be just as viable as a birch ply. I would still resin-coat.
05-23-2016, 04:11 PM #6
David mentioned our route above ... Dusty used a thin sheet of trimmed birch ply, laid over a sheet of plexi-glass for our amp rack covers.
2016 Moomba Mojo
2006 Supra 24SSV - Traded
05-23-2016, 06:25 PM #7Stuff like acryllic or hdpe would be too expensive
05-24-2016, 08:45 AM #8
I've had good luck buying scrap parts of hdpe or ks. most plastic shops I have been to have scraps laying around for sale and if you are covering in carpet, color doesn't matter.
05-24-2016, 09:12 AM #9
It can be bought on Amazon for decent prices as well.
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
05-24-2016, 10:28 AM #10
