Results 1 to 10 of 10
    Apr 2014
    Default Heater Doesnt Start Unless I Punch It
    My Heatercraft Heater worked great last year, but this year when i hit the switch i get nothing. I found that either hand spinning the fan before turning it on, or hitting the heater with a screwdriver or something with the power on, will get it working. so there's a corroded something, somewhere, it seems. Anyone fix this?
    I have two calls into Heatercraft where they need to reach the tech guy, who hasnt been available, and no call back...
    2002 mobius LSV
    Lake Minnetonka, MN
    Feb 2016
    If your smacking the motor, then it will run fine. Then the motor is bad. It has a bad spot in the armature.
    2016 Moomba Craz
    Gunmetal W/ flake
    Atomic Orange Accent
    Black Deck and Hull
    May 2010
    Salt Lake City, Utah
    You can take it apart and make sure there are no loose wires or connections anywhere. If it's ok then like Brokeguy said, probably the motor. I just replaced my motor last year, my breaker would keep tripping. It's a pretty easy job to replace the motor.
    Scott
    2007 Mobius LSV with a lot of great upgrades and mods
    Apr 2014
    Quote Originally Posted by 996scott View Post
    Awesome, thanks. Was the motor expensive? Ill maybe rip that heater out tonight and look into it....
    2002 mobius LSV
    Lake Minnetonka, MN
    Aug 2009
    Montana
    or carry a BFH this season LOL
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Apr 2014
    HA your plan sounds pretty good actually.
    2002 mobius LSV
    Lake Minnetonka, MN
    Mar 2003
    s.e. washington state
    I had to replace the heater core in my 98 Moomba and the blower was a single speed motor and looked like the blower in the bilge compartment. The box was riveted together so I had to drill those out. Pretty simple design.
    1998 Mobius
    310 HP PCM
    SOLD
    colorado
    I mainly thought it was a PITA to crawl under the bow and remove the blower, the water supply lines were really short, so i added length to loop around and connect the heater easily, then screw back to the wall. I had not drained the heater adequately one year and froze the core. have not had any probs with the blower though.
    19 Mondo
    08 LSV, forever loved
    Arkansas
    Quote Originally Posted by ranger098 View Post
    Z
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    May 2010
    I think it was around $140 for the heavy duty one. Depends on which motor you buy. You can buy directly from Heater Craft or there are a lot of other suppliers. Good Luck.
    Scott
