Results 11 to 20 of 21
Thread: New Jabsco Ballast King
05-13-2016, 05:58 PM #11
05-18-2016, 12:57 PM #12Senior Member
- Jul 2009
- Marquette, Michigan
- 141
Would this work?
2019 Moomba Mojo
05-18-2016, 02:14 PM #13
Yes it would.
Joe
2014 LSV
2010 Outback V - Sold
1993 Echelon
05-24-2016, 05:55 PM #14
That is a pretty cool relay layout. At first I didn't think that it would work until I followed each relay's input path.
I am assuming that the main switch that controls it, marked "Switch" in the diagram is a three position switch with a middle non-contact "off" position in the middle?
Up or to the left (pole #1) would control the 85/86 trigger input of the bottom relay
Down or to the right (pole #3) would control the 85/86 trigger input of the top relay
Middle would be off for bothSent by the random thoughts from the voices in my head...
Eric.
05-25-2016, 12:16 PM #15Senior Member
- Jul 2009
- 141
Exactly right. Here is exactly how I'm thinking about wiring it in using the existing plugs that come on the Mojo. I'm planning on putting both relays inside a plastic project box to help with ignition protection. The relays are supposedly "marine," but a little added safety can't hurt.
I'm using these wire harnesses if you want to follow the wire colors I listed on the drawing.
2019 Moomba Mojo
05-25-2016, 01:05 PM #16Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
...well it could actually be worse than not. A plastic project box would only slow down the air exchange rate meaning that it would eventually fill with an air/fuel vapor mix (if your bilge has this environment), but it would not be immediately cleared out when you run your blower.
For "added protection" you would need to use a hermetically sealed box. If your relays are sealed/"marine" than it really doesn't matter. My point is simply that you can't use a plastic project box and think that you've accomplished any level of ignition protection (i.e. to justify using non-ignition protected relays)2007 Mobius LSV
1989 Sanger Skier DX - sold
05-25-2016, 02:01 PM #17
Very nice.
I have used some of the different pre-made wire harnesses like those on a few different projects. For a 20A/12VDC load, make sure that you check the wire sizes on the 30/87 remote power circuit as those harnesses tend to use smaller wire gauges. I know that they are not that long, but I found it more comforting to make my own on the higher draw items such as big pumps or air compressors. It is a pretty standard female blade, (1/4" I think)
I'd like to know how that new pump works out, it would make a great rear transfer pump for switching from goofy to regular (wierdos) footed riders.Sent by the random thoughts from the voices in my head...
Eric.
05-27-2016, 08:40 AM #18Senior Member
- Jul 2009
- 141
The 30/87 wires are 14 AWG. Is that right, or should I go larger gauge?
2019 Moomba Mojo
05-27-2016, 02:14 PM #19Sent by the random thoughts from the voices in my head...
Eric.
05-27-2016, 03:07 PM #20
Thats a very common connector and female terminal. You could pop out the 14ga 30 and 87 and put in your own with 12ga wire on new terminals. Retain that connector.
