Results 1 to 10 of 10
    Feb 2016
    Default Ran over dock line.
    Unfortunately I ran over a dock line and snap it. I was able to get it untangled. Is there anything I need to look at or worry about?
    Sent from my SM-G935V using Tapatalk
    May 2010
    Salt Lake City, Utah
    when you have it out of the water just make sure the blades of the prop all look ok. You could run it out of the water for a minute hooked to the fake a lake and put it in gear and check for any vibration. You should be ok if it just got tangled.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Apr 2013
    Knoxville TN
    Lesson: keep knife in the glovebox. Seen incidents with anchor and wake lines.
    2018 Supra SL400
    Feb 2016
    It got tangled and snap the line with a loud pop. Was possibly in gear for up to 60 seconds. Then engine was shut off pulled by hand back on to the trailer. Everything looked fine after getting the rope out. Everything felt fine after words. May have heard a bit of a squeal at times.
    2016 Moomba Craz
    Gunmetal W/ flake
    Atomic Orange Accent
    Black Deck and Hull
    May 2013
    And swim goggles
    May 2013
    Vancouver WA
    Quote Originally Posted by cornrickey View Post
    And swim goggles
    I bring a dive mask.
    And the knife I have is a floating knife.
    www.TraysonsToybox.com
    Sep 2015
    UT 6000'
    That sucks Broke! Yep my boat is stocked with a dive mask, knife & extra prop just in case. You should be ok but it does take a lot to snap a dock line.
    DFTR Josh
    Supra/Moomba
    www.marine-products.com (Discount Code: DFTR-1)
    Feb 2016
    It's good to know this happens to other people.
    2016 Moomba Craz
    Gunmetal W/ flake
    Black Deck and Hull
    Jul 2010
    Louisville, Ky
    Happened to me at brostock with an anchor line. Thank god my friends had a knife and were willing to cut it loose. I think they live for that situation, I now need to get a knife and keep a mask in the box.
    2019 Moomba Makai
    2015 Moomba Mojo(sold)
    2011 Axis A22
    2006 Honda arx1200
    2006 Moomba Lsv
    2008 Moomba XLV gravity edition
    Mar 2003
    Springfield Missouri
    A friend almost lost his new boat when his boat came within two feet of hitting a navigation buoy with a river current of 8 mph when a rope got caught up in the prop. He could have moved away from the buoy if needed by running the prop even with the rope tangled up and fix that damage later.
    1998 Mobius
    310 HP PCM
    SOLD
