Results 1 to 6 of 6
Thread: Trouble starting....15 Mondo
04-30-2016, 05:12 PM #1
So last 2 trips I've had a problem starting. First time my wife couldn't get her started at the launch ramp. Told her to put it in gear and back to neutral. Then it fired right up. We parked and went to leave and same thing wouldn't start.
I called the dealer and they said cold be something in the throttle & I shouldn't worry about it since it will start after a few tries. Then bring it in when I have time (3hr trip to get boat 3hr trip to drop off boat & 5hr trip back home).
Last trip i was taking the boat off the trailer and it wouldn't kick over for like 5 minutes. I called the dealer and told them. As I was on the phone I left the key in "run" and after a few seconds it turned on by itself. So throughout the day I put the key into "run" & let the display screen boot up then turned it over & it fired up. But if I tried to do it normally (from the off position) it wouldn't start.
Any ideas before I make the truck back to the dealer?
Sent from my iPhone using Tapatalk2015 Mondo
Upgraded 900lb Rears, 250lb under Port Seat & 750lb IBS
2079 Prop
Auto Flow 2.0
Kicker Stereo: 2 800.5 amps, 2 400.2 amps, 4 KM8 towers , 4 KM10 subs & 8 KM6 cabin speakers
05-01-2016, 01:15 AM #2Member
- May 2015
- In the land of far far away.
- 31
That noise you hear in the engine bay when you turn your key on I believe is the fuel pump. Pressurizing the fuel rail. If you have any doubts about fuel delivery change fuel filter possibly.
05-01-2016, 08:39 AM #3
05-01-2016, 10:53 AM #4
Very possibly its software your waiting on, makes since you can't just start it like an older boat.
The new Raptor might be tied into the main display to check all systems before starting.
I know in my new Ram I can jump in and hit the start button but it still takes a few seconds as the dash computer boots up.
I would be concerned about messing with the throttle though. Might need a little adjustment.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-01-2016, 11:36 AM #5
Yeah but it didn't do it at all last summer???
2079 Prop
Auto Flow 2.0
05-02-2016, 06:39 AM #6Senior Member
- Aug 2008
- Hilliard, Ohio
- 794
Have you checked the battery connections? Might have loosened over the winter?
