Results 1 to 10 of 12
    Jan 2005
    Default New Prop. Has Any XLV Owners Tried It Yet?
    I currently have the OJ 13 pitch by 15.5 Wakeboard Prop. I kept hearing things about the new 14.25X14 LH XMP EDGE from OJ. I guess it came out early this year, and the people with big boats, and a lot of ballast are raving about it. I ordered one this afternoon. The salesman really talked this prop up. He said I will run 500 RPM's less @23 mph. (hopefully I can see some better fuel mileage) And the hole shot will put my old prop to shame.
    Has anyone tried it yet??? The salesman said that it is going to be offered as optional equipment on a lot of the 23+foot wakeboard boats including the XLV next year.
    The only thing I was worried about was revving it to high, but the salesman said it would not be an issue. I will get the prop Tuesday, and report back when I test it out.
    http://www.skidim.com/products.asp?d...=&sort_by=
    Jun 2003
    Louisville
    Default Replying to Topic 'New Prop. Has Any XLV Owners Tried It Yet
    I just put a 13.7x19.5 XMJ on my Outback V to improve the slalom wake. That prop size of course wouldn't work for wakeboarding -let alone for weighted wakeboarding, but I wanted to point that the prop practically elimited the wake behind the boat at 34 mph. I don't talk tech with may wakeboarders but XMJ is renowed in slalom land for improving (shrinking) the wake.
    When I bought the prop I asked the tech shop who is still buying the 3 blades. I was told that the 4 blade is great for hole shot and minimizing the wake behind the boat. The new larger 3 blades (like the new ACMEs) are almost as good at hole shot and will leave and larger wake once on plane.
    Probably something to ask your salesman before purchasing.
    2006 Outback V
    Oct 2005
    Central FL
    So ? How much has the wake improved ???
    Sounds like an interesting alternative.
    -Joe
    Mar 2005
    t-town
    I switched to tne new prop 14.25 X 14 and it has been amazing. Brian R recommened it to me with the ballast that I was running.
    It may improve the wake some, but has much better hole shot and maintains speed much better.
    db
    Jul 2006
    Austin, TX
    I recently had a buddy bend my prop on a rock and am looking for a replacement. My dealer told me that I could not change the size without voiding my warranty. It sounds like that is not true. Should I go with the 14.25x14 and what is the best place to order one from.
    Does anyone have a prop for sale?
    Thanks.
    Mar 2005
    t-town
    Voiding your warranty, heck the prop you are talking about is a option that is avail.
    i checked around and the best price I could find was skidim.
    Jul 2006
    Austin, TX
    Thats what I thought...Must of been talking to a rookie. One last question. Is there any reason I would need to take it to the dealer to have them install and check everything or should I just swap them? Thanks.
    Jan 2005
    You can change it yourself in about 10 minutes if you have a puller. But if you hit that rock hard enough, you might have done other damage.
    You can send your prop to OJ Propellers directly, and they will repair it, or if it's not repairable, they will give you a discount on a new prop for your old one.
    I have used my boat with this prop a couple of times now, and I wish I would have had it last year. The hole shot is incredible, and like the salesman said, i run 500 less RPM's @ 23 mph.
    Jul 2006
    Austin, TX
    I'm pretty sure they can't repair it. Its in bad shape! Guess I'll be without a boat this weekend. Thanks for all the help!
    Jan 2005
    AustinXLV, if you send your old un-usable prop to Eric @ OJ props, he will sell you a new 4 blade for $350 shipped.
    For anyone thinking of changing to this prop, I shut my perfect pass off to check what the top speed was with this prop. I had 3 people with, and no ballast, 34mph was the top speed. I could see my fuel gauge dropping, so I don't plan on ever doing that again.
  1. LS owners!
    By zegm in forum General Chat
    Last Post: 02-10-2008, 09:57 PM
  2. Texas Owners
    By alexr in forum Boat Owners
    Last Post: 09-13-2007, 01:49 PM
  3. Looking for Moomba owners
    By rshea99 in forum General Chat
    Last Post: 07-23-2007, 06:41 PM
  4. WAKEBOARD PRO PROP VS STANDARD MOOMBA PROP
    By DMON in forum General Chat
    Last Post: 05-14-2007, 10:14 AM
  5. SD owners
    By Isabeloutback in forum General Chat
    Last Post: 10-04-2004, 04:45 PM
