Results 1 to 3 of 3
Thread: impellar change dillemas
07-06-2006, 09:51 PM #1Junior Member
- Jul 2006
- 1
Can't seem to get the pump off of the pulley after removing the 3 allen screws and bracket.Any tricks or am I doing something wrong?Thanks
07-06-2006, 10:03 PM #2
Replying to Topic 'impellar change dillemas'
The first time I pulled mine, I like to never got it off. It took a lot of "pursuading" to get it to let go of the harmonic balancer. I just worked it back and forth and I sprayed it with WD40 and left it over night. If you do this, make sure you do not get it on the belts! After I finally removed it, I sanded the edges of the water pump with a real fine sand paper. I also sanded inside the harmonic balancer. I then gave it a lite coat of WD 40 and put it back together. This year, I unbolted it and it slid right off with minimal effort. It seems that the first one is the only difficult one. Hope this helps. Good luck.
15 Mondo Surf Edition
02 LSV - Traded In
07-10-2006, 01:50 PM #3Member
- Mar 2005
- Central IL
- 51
Mine was pretty hard to take off as well. I ended up pulling the whole pump off the engine and then coaxing it out. Hope it is not this hard next time.
Oil change
By drewdwn in forum Service & RepairReplies: 2Last Post: 04-27-2007, 07:53 AM -
Changed my first impellar
By Rugburn in forum Service & RepairReplies: 4Last Post: 10-11-2006, 11:07 PM -
Impellar Problem
By silverski in forum Service & RepairReplies: 2Last Post: 08-17-2006, 11:34 PM -
Still Overheating - impellar and therm changed
By Derteeberd in forum Service & RepairReplies: 10Last Post: 07-13-2006, 08:16 AM -
Oil Change and Impeller Change
By MartyC in forum Service & RepairReplies: 2Last Post: 03-14-2004, 10:22 PM
